Results 1 to 19 of 19
Thread: Water Balanced/No Chlorine producing from the SWG
    Apr 2014
    Florida
    14
    Hello we are new to this and trying to figure what our problem is..
    We took a sample water to the pool store: She told us other than not having chlorine everything else was fine. We just had C60 Pentair SWG put on in place of the C40 (this was replaced because it was not making salt) We also have the white flakes and the pool looks ok but I think could be better. Any help would be appreciated...Thank you in advance
    FC 0
    Salt 3900
    CH 260
    CYA 99
    ph 7.4
    TA 110
    Copper 0
    Iron 0
    Phosphates o
    PebbleTec, inground pool, 15,200,IC60 Pentair IECG, Heliocol solar panels, Pentair Intelliflo variable speed pump
    Re: Water Balanced/No Chlorine producing from the SWG
    CYA at 99 is a serious problem. You don't want CYA above 80. Worse, most of the common CYA tests will report anything over 100 and something right around 100, so your actual CYA level might be much higher. Of course it is also possible that the CYA test is just plain wrong, but high CYA fits with your other comments.
    It would also be a huge help if you had your own top quality test kit. It is far simpler to make progress when you have reliable test results available right when you need them.
    Finally, you shouldn't expect the SWG to raise FC from zero all by it's self. You should get everything balanced and working smoothly and then have the SWG take over. At this point that probably means replacing water to get CYA down and then SLAMing the pool, but it might be best to wait until you have your own test kit to confirm the CYA number before doing that.
    Meanwhile, I recommend doing some reading in Pool School in your spare time.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,012
    Welcome!
    Odds are, if there's no lights on, the SWG is working. If you had your own test kit, it would be super simple to just stick a cup down at the return jet and get some water straight from the SWG and test it then and there.
    What is probably happening, and I say this because it's hugely common, is that the chlorine level was kept too low for the CYA level for too long and now there's something growing in the pool. The SWG is probably just keeping things in a stalemate. The water might not even be cloudy yet, but a couple days of hot weather and BOOM, you're green.
    Another thing I've noticed is that pool stores use 99 for CYA as a sort of code that means "off the scale". They do the same with CH; you'll see 300+ listed there. That being said, I wouldn't trust the pool store readings. You could be just fine and they messed up the test. The only way to be sure is to test it yourself.
    If you're willing to learn the basics and invest in your own test kit, we can get that pool sparkling like you've never seen it sparkle.
    Apr 2014
    Florida
    14
    We will def get a test kid and read Pool School...Thank you for your advice.
    Apr 2014
    Florida
    14
    UPDATE: We have talked with our pool builder and they suggested turning our pump up higher and running it for longer. We run it for 9 hours so we bumped it up to 12 and turned the SWG to 80. We also started out with Chlorine at 4.... The water is very clear around 85..Im still waiting on my test kit to arrive. Builder doesn't seem to know what is going on but tells us not to lower the stabilizer below 80...said we are ok at 100? I am very puzzled as our info says 30-60....
    today we are at
    Chlorine 2
    PH 7.4
    TA 100
    Stabilizer 100
    CH 320
    Salt 3600
    38,301
    For a SWG pool, we recommend a CYA 70-80ppm. A little higher is fine as it will let the SWG not work as hard due to FC losses to the sun ... BUT ... if a problem develops that requires the SLAM process, then the high CYA becomes a bit of a problem because the required FC levels are very high.
    Don't be surprised when you encounter people in the pool industry who do not understand the CYA/FC relationship ... very common unfortunately.
    We will know more when your kit arrives.
    As I mentioned earlier, your CYA/Stabilizer level is too high. You need to replace water to get CYA down to around 80 (at the highest).
    You almost certainly have a low level algae problem, which you are never going to be able to get on top of until you lower the CYA level.
    There is no telling how high your CYA level is currently, as all of the common tests will report levels over 100 as 100. So your CYA level might be 100 or it could just as well be 300.
    Mar 2007
    San Rafael, CA USA
    12,082
    The InteliChlor IC60 Generator is rated to output 2.0 pounds of chlorine in 24 hours. This is 0.657 ppm FC per hour in 15,200 gallons. 9 hours would be 5.9 ppm FC while 12 hours would be 7.9 ppm FC. So these are extraordinarily high levels. As nearly all responses have indicated, it's going to be harder to SLAM your pool to kill off whatever is growing (likely algae, possibly biofilms) if your CYA level is high.
    Since you have white flakes, it sounds like you are getting calcium carbonate scaling in the cell and that will prevent it from producing full output. Your pH, TA and CH numbers are not extraordinarily high so I suspect those numbers are not correct. Getting your own test kit, the TFTestkits TF-100 (or the Taylor K-2006) will tell you the truth of what is going on.
    You also seem to have posted the same question in this thread on another forum.
    Apr 2014
    Florida
    14
    chem geek...sorry about the other thread ..thought it was this one...now have it bookmarked.
    We are still not able to hold the chlorine ...here are the readings we did today...we ordered the Taylor K-2006
    FC 1
    PH 7.4
    TA 100....we did put MA of 16 ounces in had not rechecked
    CYA 70...this was just when the black dot disappeared
    CH 350....we also have the white flakes but not as many now
    Salt 3600
    Water Temp 85
    SGW on 60%
    Our builder said the next step would be to have the InteliChlor company out to check water....
    Richard320's Avatar
    Jan 2010
    19,012
    Get some bleach in there before that pool turns green! Treat it is a bleach pool until you get your kit and can get some CC readings. Then you'll know if you need to SLAM or not.
    Apr 2014
    Florida
    14
    Ok will do .....what about the flakes? is there anything we can do for them....we have put in scale free to help with the cell.
    Richard320's Avatar
    Jan 2010
    19,012
    Quote Originally Posted by Bobbkate View Post
    I don't know. Never seen it. I'm a jug-dumper.
    Apr 2014
    Florida
    14
    Thank you for your help...bleach has been put in.
    Better test results will make things clearer, but for now the most likely possibility is that you need to SLAM the pool.
    Apr 2014
    Florida
    14
    Ok I received my test kit Taylor 2006 here are my readings
    CL 1
    TC 1
    CC 0
    PH 7.2
    TA 90
    CH 375
    CYA 80.. this a hard test...took outside back to sunlight and got 50 both times...then took it inside back with sun coming thru and it was 80 twice
    WT 84
    PH, TA, and CH are fine.
    CYA we need to narrow down a little. The CYA test is designed to be read outdoors standing in direct sunlight, but with the test vial shaded by your body. Based on your description it sounds like that means CYA is 50.
    I suggest you do an overnight FC loss test. If you pass then CYA needs to be raised to around 80. If you fail you need to SLAM the pool.
    Apr 2014
    Florida
    14
    Ok thank you...will do the overnight FC loss test...I have a feeling this needs to be done...
    May 2014
    Turlock, CA
    55
    Get some more bleach in there, and add more regularly.
    With your CYA, your should try to *never* let your FC get below 3-4 ppm.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
    Apr 2014
    Florida
    14
    I have added more bleach and have..tonight I will do the overnight fc loss test.
