Results 1 to 8 of 8
Thread: leaky valve
    Apr 2010
    Central NJ
    227
    leaky valve
    I have a valve that is leaking and would like your opinion on which valve should I replace it with and should I do it myself (I have never dabbled in PVC). Below is a picture, the one that is leaking is the one on the left, but I plan on replacing both. Any help on how to replace is greatly appreciated.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: leaky valve
    Where exactly is it leaking? Those unions, unless they're cracked, can't really go bad. The o-ring inside might be bad, and that is a really cheap and easy fix.
    Apr 2010
    Central NJ
    227
    Re: leaky valve
    it seems to leaking from where you turn it. I actually found a position where it's not leaking, so now I'm able to vacuum the pool. but I'm afraid that when I open it again, it's going to start leaking. How do I open? Can you point me to a parts diagram?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: leaky valve
    Oh sorry, now I understand...those are the combination ball valve/unions? (I only saw the nut and not the valve stem before, so I couldn't see what you were talking about.)
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: leaky valve
    Quote Originally Posted by Smykowski View Post
    Looks like it. Replacing with something similar to Hayward Valve
    Check around on price and from different manufacturers and Amazon. Jandy makes some good ones too from what I've read on TFP.
    Isolated Spa - 345 Gallons
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: leaky valve
    Not sure, but it may be fixable. Google "union ball valve overhaul" and you might be able to find a way to replace seals/o-rings.
    Apr 2010
    Central NJ
    227
    Re: leaky valve
    I'm considering replacing them with the jandy neverlubes, but some of them have the description that says positive seal and other don't. What is a postive seal and should I get one with it or without?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: leaky valve
    As far as I know, positive seal means it doesn't seep past the valve when in the closed position. Most that don't specify this do seep a bit, especially the hardware store variety. When I shut my valves for filter cleaning, there is a small but steady flow of water through each valve.
