Thread: Looking for suggestions towards the next pool.
    As per my earlier thread, the AG we have now is a temp unit...I'm wavering between two styles for the next pool.
    Semi in ground, similar to..
    http://www.westwoodpools.com/Images/semi_ig2_5304.jpg
    Or an above ground with insulated walls, similar to...
    http://radiantpools.com/
    If you either of these types of pools, I would appreciate if you could tell me which vendor you have, where you bought it from and any good or bad experiences you had with it.
    T.
    Size: 24' dia ~12,000 gallons
    Filter: 200 lb Jacuzzi sand filter
    Type: Above Ground
    Liner: Vinyl
    Pump: 1 HP Jacuzzi
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Looking for suggestions towards the next pool.
    Radiant pools are quite popular on this forum.... They also have a lifetime TRANSFERRABLE warranty.... That's pretty good.... Sharkline and Doughboy pools are also popular....
    You can sink a radiant half way or all the way into the ground.... That's a bonus....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
