The 2 GFCI's are both for the pool... Top one is for the pump (not sure what else need to look it over - will do that today as well) but the blue wire in this case is the neutral wire (will get back on what goes where.
the bottom of the two is the one that is tripping, the red, black, white wire is the one that goes from the breaker box (in my house) to the equipment pad. you say it cant have a GFCI on this circuit I want to be clear so I understand...
that red/black/white wire does feed two circuits:
1. a switched wire from my house to the lights.
2. a switched wire to the booster pump at the pad.
3. a switched wire to the heater at the pd.
Three wires that run outside to the equipment pad:
Red (goes to a yellow wire nut that has a black wire that goes into the wall to the switch I think).
Black (goes to a yellow wire nut that has another black wire going to the gfci and also a white wire that goes into the wall (to switch I think).
White (goes to the gfci)
so for clarity I have the one breaker in this circuit, it is tied to a wall switch (that is inside the house)then it goes out the house, in the ground to the equipment pad at a junction box. There its split off for the lights, the booster pump, and the heater... (heater and booster pump have their own switch at the pad).
coming back with more info on the first gfci, but it never trips...
Update:
also running out to the pad is a Blue, Blue, Green wire (all these wires say THWN) this is the 230 or whatever circuit for the Pump...
Green runs to the ground bar
Blue runs to the breaker
Also this might help better than words:
I will get into the junction box later today.
