Thread: Opening pool - light niche
    Last year was the first year I owned my pool and I closed it myself using this site and some information from the previous homeowner.
    This past weekend I semi-opened the pool. I did everything except for getting the water circulating because I am having a new sand filter put in later this week. One thing that I did when I closed the pool was removed the light fixtures niches from the holes in the pool and sunk them with weights (this is what the previous owner did). I have not screwed them back into place yet so I am wondering if I can leave them off so that when I slam the pool (it is dirty and slightly green) once the sand filter is running the back of lights and their niches and the holes in the pool wall will also get the slam process?
    Or should I just screw them back on? Also- do I really need to sink these to the bottom each year when I close?
    Thanks!
    16' x 37' Rectangular Guinite Pool w/ autocover 21,000 gallons.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: Opening pool - light niche
    I'm curious why you did that with the lights, vs just leaving them in...where are you located too? Curious on your climate extreme in winter.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Quote Originally Posted by steveg_nh View Post
    The main reason, right or wrong, is because that is what the previous owner did each year. I had thought it was to reduce the chance of them freeaing and cracking... I live in Wisconsin and I drain the pool below the return jets which would also be about the height that the lights are.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I asked my pool builder about the water in the light, as my pool was drained below the skimmers and jets. He said "It wont' freeze down there and in 20 years, I've never had an issue with it."
    I actually wonder if the water drains out if the water was lower than the niche, or if there is just room for ice to expand so it doesn't cause damage.
