Results 1 to 12 of 12
Thread: Water Temperature (How do you get it with your pool)?
    Southern Indiana
    229
    I have a heater that I run when its too cold to swim... I can see what the current temp is on it... but other than that all I have is a floating thermometer and it seems to be wrong more often than not... I am thinking it gets surface temps due to the depth of the thing... Is there another thing I can add to the plumbing that will give me a reading without me having to turn on my heater to check it? Or should I just leave my heater on (but in standby) while I am tracking the temps...
    just not sure is all, looking to see what is common out there.
    thanks
    Pool 16 x 33.5 Foxx Pool with rounded corners 3.5 at each end and 5+ in the middle (16000 GAL)
    Equipment - 300 LB Hayward filter with a Pentair SuperFlo pump (3/4 HP). Also Hayward H series Heater and a dedicated jet for a Polaris 280 with a booster pump (3/4HP). Hayward Chlorinator CL200.
    Pool has Main Drain, 2 return Jets with 1 inch eyeballs, a skimmer with floating weir, and the dedicated Polaris jet. Also has a valve for the Waterslide.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Re: Water Temperature (How do you get it with your pool)?
    Google Pentair pool thermometer.
    You will need to plumb in a PVC T, with a threaded fitting, for it to go into. I have two, so I can see the lift from my solar.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Southern Indiana
    229
    Thanks man... this is more or less what I had in my head but I couldn't fine anything like this.
    Southern Indiana
    229
    Just made my order... will let you know how it works out..
    http://www.sunplay.com/Pentair-Inlin...DW-p/sl1dw.htm
    thanks agn
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I have a digital display on my Aqua Solar controller that shows temperature in the pump room, and also keep a small aquarium style digital thermometer around for spot checks (also use it on the hot tub). The aquarium thermometer is handy as it has a 8 or so ft long sensor lead, so just toss it into the water and read the temperature while standing up. I think I paid about $10 for it off amazon
    Southern Indiana
    229
    is that Aqua Solar controller, for solar heating I would guess? I may get into that next year... my pool water seems to stay cool year round... but then we like it warm.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes it is
    Southern Indiana
    229
    Nice... thanks...
    This thread is perfect, I was just debating on what crappy thermometer to buy for the season.
    Change of plans, this is much better!
    To mount it, does it require a PVC 1" threaded female connector..?
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Southern Indiana
    229
    Speedo, what I plan to do is just like the pic above... I will use a 1.5 pressure PVC "T" with a bung that reduces to the threaded nylon insert for the thermometer...
    beyond that I am not 100% sure of the size but I will know more once I get it in... Pete might be able to fill in the blanks...
    I like the idea...
    Feb 2012
    Maryland
    400
    Im always curious which of mine to believe.
    I have 3, salt cell, inline digital and floating analogue type.
    Salt Cell reads 69
    Inline Digital reads 75
    Floating eads 71
    I have the pipes insulated around the inline one.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    I suspect you will get the one with a 1/2" plastic threaded "thermometer well". I have 2" plumbing, so I used a 2" T, a 1.5" reducer, then a 1.5" to 1/2" threaded plug.
    Basically, you need to thread a 1/2" threaded male connection into your T, and your T into your pipe.
