Results 1 to 9 of 9
Thread: My pool, thank you TFP!
    Apr 2014
    Pittsburg, KS
    17
    I was just cleaning some stray leaves and tree junk and marveling at how clear the pool looks. I could even see the two spiders in the deep end that needed removed Ten days ago I was ready to throw in the towel on this pool and now look at it! Thanks for all your replies and help as I learn the TFP way.
    16,000 Gal IG pool, gunite construction, intellichlor SWG, Hayward sand filter, 1hp pump
    First year pool owner: 17,000 gal IG gunite, kidney shape approx 13' x 17'; 1 HP pump, Hayward sand filter, Intellichlor SWG, Polaris 280 robot, all run by EasyTouch. Using TF-100 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: My pool, thank you TFP!
    Now stick around and encourage others!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You did the work, so give yourself a pat on the back.
    It really is easy, just a bit overwhelming at first. Once you "get it", pool care is really less work than mowing the yard that used to be there.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    good job!
    Orlando, FL
    690
    We need a "like" button. Your pool looks great and I know you must feel wonderful because you did it yourself!
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Butterfly's Avatar
    South Carolina
    10,045
    That water looks wonderful!
    You're done SLAMing when:
    Smykowski's Avatar
    Sep 2011
    3,065
    Good job and great post! People like you are the reason I spend so much time on this site: 10 days ago you were ready to be done, and now you love your pool again.
    We're starting our busy season, so please stick around and help others with your new knowledge.
    Casey's Avatar
    SW PA
    10,446
    Look at that water!!! Beautiful!!!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    That's a beautiful pool with sparkly water...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
