Thread: Salt Water Pool HELP
    May 2014
    Georgia
    2
    I have had my 27 foot above ground pool for 1 year now. My problem now is the pool store that I bought my pool from is out of business. They were great people and took great care of my pool. Now I am on my own.
    The local ace hardware can test my pool water at no charge but I dont think they have a lot knowledge on SWG above ground pools. My question is what do my numbers need to be at. I know about PH but what about other important numbers.
    They keep hounding about my Calcium Hardness its at 40ppm now. Never heard of that from the pool store. I am not an idiot, just do not know a lot about this pool stuff. Thanks for hearing me out. Any help would be appreciated
    Re: Salt Water Pool HELP
    Check out the recommended levels under Pool School, Pool Chemistry, Recommended Levels for SWG pools. I have a SWG pool and it is pretty easy to keep in check once you have it set. Let us know if you have any questions. Calcium hardness is easy to adjust, but the level you want depends on the type of pool you have.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Welcome!
    You have a vinyl pool. Low Calcium is not going to damage it like it would a plaster pool. I will assume the hardware store is just being cautious, not malicious. Lots of people honestly don't know their surface, so it's better to assume it's plaster.
    Have you visited ? The answers you want are in there.
    Major hint: Invest in a proper test kit right now, before you even start reading pool school. Best value is a TF100. I suggest the XL option right now because pool stores don't usually carry the FAS-DPD reagent, and you don't want to run out. Order today, you'll have it in your paws before the weekend. Also, the speedstir is a great addition. Nobody who has one regrets buying it.
    Oct 2013
    Chapin, SC
    1,141
    My local ace hardware also does free water tests, but all they're really interested in is selling their pricey (very) chemicals. They know absolutely nothing about bbb, nor do they care to know!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
