Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Outdoor Speakers
    Aug 2013
    Huntington Beach, CA
    54
    Outdoor Speakers
    I am planning to run speakers on the far side of the pool. I don't have power so I'm going to run speaker wire through a planter that surrounds the pool.
    I need suggestions on outdoor speakers. I don't have a preference if the speakers are camouflaged or not. We have a lot of tropical foliage so it will get lost in it regardless if it's rock shaped or looks like a speaker.
    I also need suggestions on outdoor wire. We live in Souther California so weather is pretty temperate.
    Thanks for the help.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Re: Outdoor Speakers
    I have two TIC GS3's by my pool and I love the sound (see the link below). I also put in regular outdoor speakers by my deck. The GS3's are fairly large and I partially buried them in two garden areas. They are big and require power from a receiver, but put out great sound.
    http://www.amazon.com/TIC-GS-3-150-W...pr_product_top
    If the above speakers are too big or powerful for your receiver, I've heard good things about their smaller version, the TIC GS5.
    You don't need speaker wire. I used 14 gauge low voltage direct burial landscape wire from Home Depot, cheap and will survive year round in any weather.
    Below is a link to my thread when i was deciding on what to do with my sound system... post #7 has all of the details on what I decided to buy and install.
    http://www.troublefreepool.com/threa...tdoor-Speakers
    Best of luck!
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    As mentioned use landscape lighting wire. I'd go for 12 awg but 14 should be just fine. There is nothing special about speaker wire. It just needs to be a large enough gauge to keep the resistance happy at the amplifier.
    I've got some b&w outdoor speakers. Probably overkill but I'm a pro sound guy...
    14,000 gallon IG plaster pool, Cartridge Filter
    Feb 2013
    Powder Springs GA
    9
    I installed a pair of AP850's from Outdoor Speaker Depot last year and am very happy with them. Planning on a second pair this season. I also bought the AMP200 to run zone three in the basement, which includes the AP850's by the pool and 4 other pairs of Sonance in-ceiling 8" in the basement. Each pair sits behind a volume control and the amp happily drives all to well past respectable volume levels.
    32K IG Vinyl (2006) - Hayward S244t Sand Filter - 3/4 HP Superpump - Circupool Si-45 Plus SWG - TF-100 Test Kit
    Feb 2013
    Powder Springs GA
    9
    To be clear, the AP850's are quite large and quite loud.
    The most important question for you is what end result are you looking for? Music volume level can be accomplished a couple of different ways. Do you want background music that is fairly even no matter where you are? Or do you like it loud and in stereo?
    Larger speakers, placed 6-12 feet apart will preserve stereo imaging, while multiple smaller speakers running mono and sprinkled throughout the area will give even sound at lower volumes.
    Quote Originally Posted by Dubyahjay View Post
    Apr 2012
    Newton, NC
    173
    I read through the various posts on TFP about outdoor speakers and did a bunch of research on other websites and decided to go with a pair of Polk Atrium 8 SDI's. FedEx delivered them today. I will be mounting them on the end posts of a pergola about 8 feet above the ground pointing toward the pool.
    I'm ready to rock and swim.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    Aug 2013
    54
    Wow, great advice. I'm looking for background music, but I like it somewhat loud. I'll have to feel out the neighbors once I get speakers installed.
    I like the 360 sound idea. Especially for a particular spot around the BBQ island/spa.
    Quote Originally Posted by Krisher View Post
    I have 2 sets of the Stereostone Davinci series outdoor rock speakers around the pool and they sound great. I also have the Polk Atrium speakers on the patio. They also sound good Remember you get what you pay for.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    http://www.crutchfield.com/p_760CS10...000-White.html
    Have had these for 1.5 years. Very crisp, even at low volumes (evening by the spa or AM swim). No doubt they can crank but I really wanted a low volume that I can hear from all parts of the immediate backyard and still be able to appreciate the detail of the music. Expensive but worth it for the amount of time we spend around our pool.
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    My outdoor Stereo Build... Don't go cheap on the wiring gauge. My amp runs super cool all day.
    http://www.troublefreepool.com/threa...r-Stereo-Build
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Quote Originally Posted by VinceL View Post
    These are awesome speakers...I put these in for my neighbor. I have 3 year old Atrium 65SDIs. Just unreal. The outdoor environment stinks for speakers, as there's nothing for the sound to bounce off of, but these things get it done. Enjoy them! Of course, drive them with good clean, high current power to get the most out of them.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Aug 2013
    54
    Should I run one wire on far side of pool and tap into it for the two speakers I plan to mount. Or run two separate wires?
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    IMHO two.
    Depends on the amp and speaker combo though.
    Two is the "safe bet".
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2012
    Montville NJ
    545
    I got two sets of old Drive In Movie theater speakers from my father in law last fall. Two speakers per pole, and two poles. Over the winter I I cleaned them up (Wire wheel) and took the guts out and replaced them with polymer cone car audio speakers (so they hold up to moisture).
    I ran them off the system in the garage and they sounded pretty good, but they look so cool. Once I finish rebuilding this poold deck, I am going to install them around the paito. My wife says there go there, and not on the pool deck. If nothing else, I can follow instruction.
    Just an idea. I know people like to hide speakers in rocks, etc. But I figure, if you have some interesting looking enclosures, why not make them a design element.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Aug 2013
    Chandler, AZ
    117
    Quote Originally Posted by phonedave View Post
    -dave
    That is a pretty good idea permitting you have them. Those things are expensive!
    12.4k IGP 27'x14'x4.5', Pebbletec, Pentair EasyTouch, Pentair Intelliflo VS, Pentair IC40, Pentair Quad DE 80
    May 2014
    MILLSTONE TOWNSHIP, NJ
    87
    My Rockustic rock speakers on far side of pool finally have had it after 15 years! So looking for new ones -- anyone like the Niles rocks with 8in. woofers in them? I hear OSD speakers are really a scam -- is that true?
    I have 2 in stereo firing back towards the house that I like to "rock" (vs. background only) hooked to a separate volume control.
    All my other speakers are either Boston Acoustics or Niles attached to house "zones" via the Sonos Connect Amp..
    33,000 gals, DE, IG, plaster, Purex Triton FNSP 60 filter, Pentair Super Flo 2hp, Pentair MinMax Heater
    Jun 2014
    Copiague, New York
    1
    I am presently using Rock speakers 250Watt and I have a backyard approx. 7500sqft. The speakers are awesome and do not over power normal conversations while playing in the background. I ran my wiring under the deck around the pool. I used burial speaker cable. Little expensive but will last many years.
    Aug 2013
    54
    12 gauge low voltage outdoor wire?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Yes, 12 gauge low voltage outdoor wire.
    Karen
  20. Back To Top    #20
    Jan 2010
    Northern Virginia
    282
    I had a Paradigm outdoor speaker shaped like a rock. They're sort of high end company so it was pretty expensive ~$450 I think. I was a single speaker that provided stereo sound - you hooked up both sets of speaker wire to the speaker. It worked fine, but seemed to use a lot of power. By that I mean to hear it well at the pool, it was way, way, way too loud in the house.
    I switched over to a much cheaper rock shapped speaker from Crutchfield and I like them a lot more. I have 2 of them (left and right channels) and they are much more efficent (?). I don't need to turn them up nearly as loud as the Paradigms to get a good volume outside and inside.
    I don't see my exact type here, but I got it a few years ago so they may have changed the look/style of them:
    http://www.crutchfield.com/S-lF6RRkh...-Speakers.html
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
