Thread: Plants that do well with salt water pool.
    Anyone else have some suggestions on planting next to the pool deck. Has anyone tried Hosta's, do they survive the salt and chlorine? Any other plants that would be tolerant of these conditions.
    34,000 gal, IG vinyl lagoon shape, Pentair intelliflo varible speed 3hp varible speed pump, 2hp varible speed sheer descent pump, 520 clean an clear cartridge filter, letro legend with booster pump, 8ft bench with two 3ft sheer decents, 3 Pentair Magic Flow Laminar Jets, Intellibrite 5g led lighting, Build currently in progress
    Vegas Kid's Avatar
    Dec 2013
    Cypress TX
    187
    Re: Plants that do well with salt water pool.
    I have azaleas close to the water...no issues.
    Also have some oleanders a bit farther away, but they are poisonous so be vary if you have dogs/children
    May 2013
    Ontario, Canada
    63
    Pretty hard to kill a Hosta even if your trying. They do very well around the pool.
    18' x 36' vinyl steel wall pool with deep end, 2 lights and 6' steps, main drain, SWG, Cartridge Filter, 320,000 BTU Rheem heater, 3/4HP 1 stage pump - Ontario, Canada
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Unless you are splashing a huge amount of water on the plants, it's not going to hurt anything, even if the plants are sensitive to salt.
