Thread: Stand-pipe O Ring Missing
    Aug 2013
    Hilton Head, SC
    133
    Just noticed that the O ring on the stand-pipe inside my Pentair DE filter is missing. Is that a serious/mild issue? I've had some type of leak going on, but there is no water around the filter unit.
    I have ordered the part, but wonder if I should not run the filter until I have the O-ring.
    For those who know this unit well, it's part # 27.
    thx
    ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    38,303
    Re: Stand-pipe O Ring Missing
    You may get debris/DE passing through the filter without the o ring. Up to you if that is serious or not.
    Apr 2013
    North OKC Area
    300
    I never used a DE filter but I wonder if you could wrap a few layers of electrical tape until you get to the right thickness and use that until the part comes in.
