Thread: gas features, would like your opinion
    Houston, TX
    1,099
    Hello to all,
    First, I want to thank everyone for their continued support and feedback, it has been invaluable. We are finalizing our design and refining bids this wkend.
    Next, wanted your opinion on placement of a gas fire feature. We have a wall that runs 2/3 to the back lenght of the pool with 4 columns. The two columns in the middle will be taller than the ones on each end. The wall and columns will all be travertine-based and t-tine scuppers in the middle taller two. My question is, if we go with some fire features [bowls on top of the columns], is there a pool design std that you put the fire-bowls on the end columns or the two middle columns with the scuppers? I know this is probably a preference, but if anyone has added this feature in a similar configuration, how did you do yours and are you happy with it or would youi change it? We have everything else completely done but this aspect.
    Finally, as soons as we select our PB, I will take before, plenty of during and after pics.
    Again, I appreciate all your help and feedback.
    Best regards,
    tstex
    Readyforapool's Avatar
    Sep 2013
    DFW metroplex
    738
    Re: gas features, would like your opinion
    Sounds gorgeous! I don't have anything like that but you might want to look at houzz or Pinterest or even some PB sites to see if there are any photos similar to help you decide. Can't wait to see it!
    Finally Done! - 21x34 IG, SWCG, depth - 3.6 - 4.6 - 6.6, Pentair IntelliFlow 3050 vs+svrs, 60 sq ft Pentair DE Filter, 400k BTU Heater, Polaris 280 w/.75 hp booster pump, Pentair EasyTouch wireless, 38 sq ft raised spa, wet edge Barbados quartz finish - ODK w/36 in Napoleon grill
    Houston, TX
    1,099
    Thanks rfpool. I have viewed a fair number of PB sites and nothing jumps out at the moment...I also should have asked are there any special considerations I should note when a PB quotes this feature and if there is anything I should ask if they do from a structual perspective.
    thx, tstex
