Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Through the wall skimmer on an Intex
    May 2013
    Leesburg, Mississippi
    14
    I bought a Haywood skimmer for my Intex last year but never got around to installing it.
    Do I need to drop the water level in my pool before cutting for the skimmer, and if so, how low should I be?
    Intex Ultra 16'x48" Round AGP-5000 gallons
    Intex Krystal Clear 2650 GPH SWG & 16" Sand Filter
    Intex LED Light
    TFTestKit-100---Pool School---Pool Calculator
    Apr 2013
    Battle Creek, MI
    298
    Re: Through the wall skimmer on an Intex
    I did mine last season without dropping the water level -- in other words, I got a little wet! But by using silicone sealant on the outside gasket (mine was a Hydro Tools) and basically assembling it in place as tight as I could before cutting the side of the pool, it can be done.
    P.S. If you do it that way, don't forget to carefully re-tighten the screws after cutting
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I'm dropping the water level, I got drenched on a friends last year....lol.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2013
    Newcastle, Oklahoma
    508
    very carefully cut the butterfly gasket in half on your hayward skimmer so you have 2 gaskets, one for each side. Then place it where you want it on the outside of the pool and mark the holes with a sharpie. Then use a small phillips screwdriver to punch the holes in the liner. Mount the skimmer in place, tighten all the screws good, but not too tight.
    Hook up your lines from the skimmer to the pump. Then grab an exacto knife and cut out the square in the liner in the skimmer opening.
    No need to drain any water with this method, as loss will be very minimal.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Apr 2014
    So Cali
    5
    No need to drop water level. I did similar as already stated, cut gasket in half, use a awl/punch in each screw hole one at a time, punch a hole, run in the screw. Hook up plumbing then starting a corner cut diagonally from one corner to the other, then repeat making an X in the skimmer mouth. After that use the skimmer mouth as a guide to trim the liner out of the skimmer opening.
    I lost maybe 2 cups of water using this method.
    14'x42" Ultra frame
    Hayward SP1091LX in-wall skimmer
    Intex SWG/Intex 1000gph solar heating system
    Intex 2100gph sand filter
    1.5" PVC plumbing/1.5" Intex intake and return fittings
    May 2013
    14
    While on the subject of through wall skimmer, has anybody run two pumps off one skimmer.
    I have an intex 2650 salt system and I also have a separate pump I was thinking of using for a sprinkler.
    Was wondering if the skimmer would support both.
    They would only be running at the same time every now and then.
    Intex LED Light
    Casey's Avatar
    SW PA
    10,421
    Good Luck with your upgrade!
    joshuaberman's Avatar
    May 2013
    Harker Heights, Texas
    139
    I didn't cut my butterfly gasket in half. I mounted the gasket and inside plate first, cut the liner, disassembled it and put the gasket in properly, buttoned it up. No leaks.
    22'x52" Intex 10,472 gal. w/ 2650 Sand Filter, using Taylor K2006 Kit. BBB
    My Build: http://www.troublefreepool.com/threa...x)-Will-update
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by joshuaberman View Post
    Sent from my HTC One_M8 using Tapatalk
    looks good! and it goes to show there is more than one right way to do things!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    My Hayward dyna-skim is supposed to arrive tomorrow. Can't wait! I'd like to do as Joshua did and install without cutting the gasket, but I don't want to drain the pool down to do it. I'll look it over and decide once I have it in hand.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    May 2013
    14
    Did you lower the water level very much when you mounted yours
    Intex LED Light
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    How did you put the gasket in, without cutting the liner first please Joshua?
    May 2013
    139
    OK, I'll need to clarify. Yes my water level was lower because I did the install prior to opening for the season. I also , as some know, did the PVC upgrade as well. Because of this , I lowered it to the inlet.
    With that said, it made both mods very painless. To install without cutting the gasket, I held it in place on the outside of the pool where I wanted to mount it. I then took a sharpie marker and marked the inside corners of the gasket on the wall of the pool for reference and making sure to keep it as level as possible. No I didn't use a level, I eyeballed it. I did however check it and it wa level. 😊
    After making my reference, I popped the two top corner holes with a small Philips, then the bottom two corners. (I believe I popped these once I screwed the top two into the skimmer)
    I then mounted the skimmer in place with the entire gasket on the outside, under the skimmer, in position and screwed those first four screws in place. Then popped the rest, of the holes. Took it apart and mounted it properly. Once mounted, I cut the liner making sure not to cut through the gasket.
    I took it all apart, installed the gasket properly, and installed the skimmer and faceplate.
    Piece of cake. You'll notice there are two types of screws, the rounded head are covered by that faceplate. Those obviously get installed first. Be sure to screw them down tightly or they will bow out the faceplate when tightening the outer screws.
    Hope this helps, going off memory....
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Thank you Joshua... That was very clear and concise.... I think I'll do the same thing... I don't like the idea of cutting the gasket in half....
    May 2013
    139
    I'm rereading it and trying to remember exactly what I did. I kinda winged it. Post will be edited if needed.
    May 2013
    139
    Here's a couple pics during the install if they help any:
    Looks great! I just ordered a skimmer this morning to do my Intex pool also. I am sick of always having to skim the surface. Do the skimmer's cut that down a lot?
    Intex 16X48, Intex sand filter, Game 3/4 HP pump. Springfield Mo
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Quote Originally Posted by blaib View Post
    Yes they do... How long do you run your pump each day?
    I run it about 6 hours a day, Do you think I should consider running it more often?
  20. Back To Top    #20
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    No, that's plenty of run time... A through the wall skimmer would make pool maintenance easier for you....
