Thread: Lowering alkalinity
    Oct 2013
    Baton Rouge, LA
    86
    Lowering alkalinity
    Hi guys here are my numbers for my swg pool...
    fc-4.5
    cc-0
    ak-130
    ph-7.8
    ch-40
    cya-65
    Im raising cya to 70-80 at the moment, ill be adding acid to lower ph but what should i do about TA? What is the best way to lower? I read in pool school for a swg i shold have it around 70-80 i believe.
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    Re: Lowering alkalinity
    The simplest way to lower TA is to simply lower the PH to 7.2 any time it gets to 7.8. If the PH goes up too quickly you can lower TA more aggressively, as described in Pool School How To section. But generally that is not required.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Oct 2013
    Baton Rouge, LA
    86
    Ok i adjusted it to around 7.5 but i quickly rose up to around 7.8 or higher. From reading forums i understand that is bc i have a high TA for a swg i assume. So as if i lower my ph to 7.2 it will lower my TA as well?
    Oh ok got it. Thanks for the post, i read it earlier but didnt read the whole thing lol.
    Mar 2014
    Orlando, FL
    35
    Yes, lowering your pH with acid will also lower your TA. You will likely have to do this several times to get the TA in the range you want. As woody mentioned, see this link and it will tell you what to do: http://www.troublefreepool.com/conte...tal-alkalinity
    15k gal, Pebbltec. Built in 2004. 2 HP Pump, Cartridge Filter, Hayward SWG, Hayward Navigator Cleaner, TF-100 / Orlando, Florida
    Apr 2010
    East Texas
    9,643
    .............."i read it earlier but didnt read the whole thing lol." Shame on You!
