Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Newbie posting test using TF-100
    Aug 2013
    Hilton Head, SC
    133
    FC. 3
    CC. .5
    TC. 3.5
    CH. 6
    TA. 60
    PH. 6.8
    Pool was green when I took off cover. Shocked it yesterday and now looks clear, maybe a little pollen dust still in pool. Filter is running most of the time. We have 3 live oaks hovering over pool. Lots of pollen!
    These #'s are from 10 minutes ago.
    Thoughts ?
    Thx.
    Ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Aug 2013
    Hilton Head, SC
    133
    Oops wrong CH number
    Sorry
    The CH measure is 150, not 6. Forgot to X by 25!
    Thx
    Ed
    38,475
    Re: Newbie posting test using TF-100
    We don't "shock" we follow the SLAM Process and that is clearly not what you have done thus far based on your FC being so low already.
    What is your CYA? That determines what FC levels you need to maintain. See the FC/CYA Chart.
    Am I correct in guessing that you through a bunch of dichlor powder chlorine in the water and called that "shocking" and that is why your pH is now too low? I could be wrong.
    Step 1 is to raise the pH into the 7s with borax.
    Step 2 is determine your CYA
    Step 3 is following the SLAM process.
    You should also likely eventually raise your CH up to around 250ppm.
    Casey's Avatar
    SW PA
    10,457
    CYA results? Bring pH up. Read Pool School.
    30,431
    You can find that SLAM process in Pool School. If you will follow that article precisely, you will have a crystal clear pool.
    If your water is now clear and you are losing less than 3 ppm or so chlorine daily, there may not be a need to SLAM. However, Post your CYA to give us a better picture of where your FC needs to be.
    Aug 2013
    Hilton Head, SC
    133
    Ok let's try this again....hit me if you find an opening and yes I used a cheap a** shock package since my TF-100 had not arrived...can't fix stupid right?
    CYA. 60
    PH. 7.2
    FC. 1
    CC. .5
    TC. 1.5
    CH. 200
    TA. 140
    This is assuming I did all the tests accurately my second time go-round....
    Thoughts/suggestions very appreciated!
    Cheers
    Ed
    38,475
    SLAM away.
    Smykowski's Avatar
    Sep 2011
    3,065
    SLAM away.
    Second.
    Aug 2013
    Hilton Head, SC
    133
    Round three.
    Out of town for two days. Wife is pleased to say she shocked the pool yesterday. Used the "bad" bag of powder from home/garden store! Sigh....
    Today's #'s:
    PH. 7.2
    CYA. 70
    FC. 11. (Wonder why. :>)
    CC. 0
    TC. 11
    TA. 120
    CH. 100
    Pool temp.
    Suggestions? No I didn't yell at her. Explained why I bought TF100 and the TFP method.
    Ed
    Sorry. Pool temp 70
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    You're getting up there on the CYA now...better hide that shock it's getting you to where you're going to need to replace some water..
    Put the powder down and slowly back away from the pool!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Ouch! That CYA is climbing big time!
    If the "shock" you used was Dichlor, every one pound bag you dump in your pool adds 12 CYA and 13 FC and lowers pH by .5. The pH will recover because your TA is over 100. The FC will get used up or burn off. The CYA is the gift that keeps on giving... the pool equivalent of an STD. Easy to get, hard to get rid of.
    The biggest problem with high CYA is that your minimum FC level is 5 and your target every day should be about 8. That's above the ability of the colormatching test kit, so you'll have to use the powder and drops every single time you test FC. Your chlorine usage won't be any higher, but you'll need to maintain a higher level. It will make sense after a while of testing, dosing, and reading.
    Luckily, your pool isn't very big, so draining off some water won't create a huge swampy mess nor will it cost you a fortune to refill.
    Jun 2013
    Fontana California
    56
    It looks like you have some inconsistent test results. For example your CH started at 150 then jumped up to 200 then back down 100 over a four day period. You might watch some YouTube videos on how to perform the tests to make sure you are performing them correctly.
    ***I hope that jab didn't sting too much***
    14K Gallon IG Gunite Pool built in 2005, Century Centurion 1 1/2 HP Pump
    Pentair Clean & Clear 420 Sqft. Cartridge filter, MiniMax Pentair NT Heater, The Pool Cleaner
    Taylor K-2005 test kit with Taylor K-1515-A FAS-DPD Chlorine Test. SpeedStir
    Aug 2013
    Hilton Head, SC
    133
    Nah bring it on!
    LOL
    As to replenishing the water to lower CYA, we have a small leak in the pool so we put maybe 50 gallons or so in most everyday. We suspect the tile grout is leaking and have called a pool repair company but they haven't come on site yet.
    Aug 2013
    Hilton Head, SC
    133
    #4 on the test train
    Do not start a new thread for new test results. Please keep them in the same thread. Thanks, jblizzle
    And I do mean train!
    Here we go:
    CH. 125
    FC. 8
    CC. 1
    TC. 9
    TA. 120
    CYA. 60
    PH. 7.2
    Water temp. 72
    Comments, suggestions most appreciated.
    Thx
    Ed
    Aug 2013
    Hilton Head, SC
    133
    Re: #4 on the test train
    Mother's Day test results
    FC. 4
    CC. .5
    PH. 7.2
    TA. 110
    CH. 125
    CYA. 55
    Water looks crystal clear
    Temp. 79
    Richard320's Avatar
    Jan 2010
    19,051
    So go swimming!
    Question: How is the CYA dropping from 70 to 60 to 55? Have you been draining and refilling?
    Aug 2013
    Hilton Head, SC
    133
    We have a slow leak. Suspect the tile grout. Waiting for a service tech to come. I put maybe 100 gallons a day in the pool.
    Ed
    Aug 2013
    Hilton Head, SC
    133
    Just found out that I've been adding about 200 gallons a day to pool. Roughly 4% of pool capacity. Could that explain the lower CYA?
    Richard320's Avatar
    Jan 2010
    19,051
    Quote Originally Posted by Emarshbuck View Post
    Absolutely. And that's a huge leak.
  20. Back To Top    #20
    Aug 2013
    Hilton Head, SC
    133
    OK, back from a couple of days away....wife did not shock w/dichlor this time!
    PH 7.5
    CYA 45-50 (still trying to figure out when I don't see the black circle)
    FC 0 (nada)
    water temp 76
    water clear
    pool calculator said to put in 156 oz 8.25 chlorine. I put in 121 to be conservative my first time with bleach. Poured bleach in slowly over my two returns, one in deep end, one in shallow.
    Tested 2 hours later, looks like I have FC @ 25. Did I test too early? We get lots of sun here along the coast and it's going to be 77 degrees here today.
    Running the pool pump constantly.
