Results 1 to 10 of 10
Thread: PSI loss between filter and pentair pop up dome? What's normal
    Oct 2013
    Phoenix, AZ
    25
    My filter is currently at a rather cosistent 30 PSI, even after cleaning my filters it ranges from 25-30 PSI. At the dome its reading 10-20 PSI and I "think" i'm having an issue with weak pressure on some pop up valves.
    What is the normal pressure drop between the filter and dome?
    Thanks.
    Size of pool (gallons) = 15,000
    Pool Type: is IG (in ground)
    Construction: Plaster
    Filter type: DE
    Filter Manufacturer: SM/SMBW 2000 Series
    the size, model number or flow rate of the filter.
    Pump in HP = 2
    Pump is two speed
    Date of pool build/install = circa 2001
    with spa
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: PSI loss between filter and pentair pop up dome? What's normal
    Is there a valve to direct water to the popups? If you are only sending a little water to them, they won't be very strong, but I can't put a number on a pressure difference. Are you sure the gauges are good? What kind of "weak pressure" symptoms are you having?
    38,548
    It is pretty normal I think to see a difference, not sure how much though. The filter is measuring the pressure before the filter grids, the dome is measuring the pressure after the filter grids plus there is head loss through the plumbing from the filter to the dome.
    mas985's Avatar
    Pleasanton, CA
    11,743
    30 PSI is pretty high and close to the max for many pumps. What is your pump make/model? Does your filter gauge go to zero when the pump is shut off?
    Mark
    Oct 2013
    Phoenix, AZ
    25
    Hi there isn't a make/model on the pump for some reason but it's a 2 HP single speed pump.
    Right now the pressure is high and the pop up cleaners are not rotating correctly, zone 1 is staying active resulting in weak pressure on the rest of the system and zone one isn't rotating since its staying active. I had a pool service come by today, he recommended new filters and a new gear for the zodiac caretaker system. The filters are from 2007 presumably when the pool was built.
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    Oct 2009
    3,899
    If you open up the dome, the gears should rotate easily if you spin them with your finger. It is easy to replace yourself if something is broken/worn/missing.
    Oct 2013
    Phoenix, AZ
    25
    Quote Originally Posted by Melt In The Sun View Post
    Thanks, I'll open the dome up today and take a look at it. Something has to be off. I see they have rebuild kits for about $75 online.
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    Oct 2013
    Phoenix, AZ
    25
    I ended up replacing the internals of the polaris caretaker system with the rebuild kit. It did NOT resolve my problem though. I still have the jets at the deep end of the pool stuck in the on position and the system is not cycling. Any idea what else could cause this problem?
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    Oct 2013
    Phoenix, AZ
    25
    Problem with jets not cycling has been fixed. The check valve was stuck open somehow. I removed it, cleaned it and re-installed and now everything is cycling fine.
    I'm put in new cartridge filters and a new internal rebuild kit on the caretaker, however my PSI is still at 28-30. I'm wonder in that is just normal with a 2hp pump running?
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
    mas985's Avatar
    Pleasanton, CA
    11,743
    What is the pressure at the dome? It should have a gauge.
    Mark
