Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: The numbers
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    The numbers
    First full test on pool. As many of you know bought the house on short sale and pool not open or running in years. A month ago it was black, now it is cloudy. I have been adding in bleach. Tried the pool calc but I got a number way off the charts.
    4.5 ppm fc
    3 ppm cc
    300 ta
    7.5 ph
    190 ch
    35 cya.
    It is a plaster pool water temp is 60 degress
    thanks
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The numbers
    I take it these results are from one of our recommended test kits ? If they are then ....
    With the CC of 3 and cloudy water you need to follow the SLAM process.
    First lower your PH a bit with acid then start the SLAM.
    http://www.troublefreepool.com/conte...tain-shockingl
    Use pool math for your dosing of acid and bleach. http://www.troublefreepool.com/calc.html 😎
    Jeff
    38,290
    Re: The numbers
    Quote Originally Posted by rlefig View Post
    What does that mean?
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    jbizzle, just the TA seemed to be so high. When I put in that number the fields did not populate like on other calculations.
    TF100 test kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: The numbers
    What are you trying to adjust? I just entered all of your results into PoolMath and had no problems.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    yes you are correct, long day of moving big rocks. Just trying to clean up the cloudiness. Will look at slam again. I think i got ascared because TA was so much higher.
    TF100 test kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: The numbers
    Yes, your TA is high, but it won't hurt anything for now. You can get it down later. For now worry about the SLAM and cleaning up the water. I would bring your pH down to 7.2 and then get started.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    thanks, this patio is wearing on me. But it is getting there. I plan to lay another pallet or so of brick this weekend
    TF100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: The numbers
    A couple thoughts:
    1) The TA test is prone to errors due to static electricity. Wipe the tip of the bottle with a damp paper towel between drops. If it did have a problem with static electricity, the drops would be smaller, which would mean more drops to get the same change, which would give an artificially high TA reading.
    2) TA in itself is not harmful. You bathe in the same water, drink it, wash dishes in it. It's not critical and it's relatively easy to fix once the pool is clear. So don't sweat it.
    3) Are you still dragging the bottom for leaves and muck? If the pool was black, I suspect there would have been a lot of sludge. It will burn up chlorine at an amazing rate, which slows the SLAM process.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    Quick number test yesterday afternoon and this morning
    yesterday was
    fc = 19 ppm
    cc = 1 ppm
    This morning it is
    fc = 12.5 ppm
    cc = 0
    Watewr is still cloudy and I still have vacuuming to do. But hopefully getting there
    thanks everybody for all your help, it is greatly appreciated
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    Still slamming
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    Good morning the water is still cloudy. I have still also been scooping some leaves from bottom. Have also been brushing a lot and vacuuming some.
    I guess I keep SLAM-ing. here is a recent round of readings. Can CYA go down if no water is replaced? And is this length of time to get a clear pool normal? It has been looking better, but not there yet.
    thanks
    5/9
    fc = 13 ppm
    cc = 0
    5/10
    fc = 14.5 ppm
    cc = 0
    CYA = 20
    ph = 7.5
    5/11
    FC = 11ppm
    CC = 0
    PH 7.5
    CYA = 25
    CH = 300
    5/12
    FC = 12.5 ppm
    CC = 0
    TF100 test kit
    30,420
    Re: The numbers
    Your pics show a lot of improvement and it sure sounds like you are doing all the right things. I think it's time for some POP (pool Owner Patience). Your situation is not at all uncommon. Stay the course. Keep your FC up there just as you have been doing. Watch your filter psi to clean/backwash when necessary.
    Your getting there and doing all things correctly as nearly as I can tell.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    Thanks, I cleaned the cartridges this weekend as my newly purchased pressure gauge from here did show an increase from the normal 6-7 PSI up to 9. Plus I had no cleaned it all from the "black stage". I will be patient.
    Laying another 3 pallets of brick this weekend for the pool patio
    TF100 test kit
    Richard320's Avatar
    Jan 2010
    19,002
    Re: The numbers
    At least you can see progress!
    In light of your brushing the pool and bricklaying, I suggest you buy your bleach somewhere like Target, that also sells Motrin and beer.
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    That is a great suggestion, but in MA only Liquor Stores sell beer. I do get most of my bleach at Wal-Mart.
    TF100 test kit
    rlefig's Avatar
    Apr 2013
    Reading, MA
    200
    Re: The numbers
    Still slamming cc's are usually 0 or .5 I am still putting in LC to keep the FC at shock
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: The numbers
    Looks like you still need some SLAM time. Stay with it. It'll come around. 😎
    Jeff
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Re: The numbers
    Progress! Keep up the good work!
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
  20. Back To Top    #20
    May 2014
    Ohio
    75
    Re: The numbers
    Looking better. As a newb trying to learn, I was just curious as to how much bleach you have gone through.
    16' x 32' Hopper IG Vinyl | 19,000 Gal | Pentair Tegalus 60 Sand Filter | Pentair Challenger 3/4 hp Pump
