Thread: Will "robots" climb this wall design with ledge ?
    May 2013
    North East Ohio
    959
    trying to research robots, and I am not sure if any will be able to navigate up this wall all the way to the tile line ?
    I have this walking ledge all the way around, as you can see ?
    Or should I just focus on the floor models, knowing it is easy to brush the walls (plus save a ton of cash)
    Any feedback ?
    (cant post pics anymore, so this link will need to work I guess)
    http://www.thursdaypool.com/fibergla...n-goliath.html
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    38,548
    Re: Will "robots" climb this wall design with ledge ?
    How To Post Pictures
    Most robots I don't think work with vertical walls with a sharp transition as those pools look like. Also they are likely to struggle more with the smooth fiberglass surface. I do not think that many are able to climb up on steps/shelves/etc.
    May 2013
    North East Ohio
    959
    Ok thanks...I used to be able to post directly, guess the new layout changed the quote limit, etc. Now I cant even use FLICKR - arghhhh...will have to dig into photobucket.
    As for the climber .... thanks, that is what I was afraid of.
    So now....the research continues. Unless someone has a non-climbing option they want to share.
    Thanks!
    https://flic.kr/p/nxdqRZ
    38,548
    You can use flickr ... we just found that Photobucket was a little easier. You just need to be sure to post the URL to the photos themselves and not a folder or webpage photo viewer ... sometimes called the "direct" link.
    May 2013
    North East Ohio
    959
    Ok...figured out flickr.
    Below is my design.
    pool 3d view by Jed Cavadas, on Flickr
    30,432
    As a general statement, no robot will climb those walls successfully.
