Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Hayward PVC plumbing
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Exclamation Hayward PVC plumbing
    I will hard plumb my Hayward Perflex EC50 filter and Hayward 1.5hp Power-Flo LX pump. Can you please let me know what I need to connect the PVC piping to motor,filter ,skimmer and pool outlet? Are all the threaded connectors available at local supply store? In the filter manual it says that all the plumbing connections are 1-1/2" NPT. Does it mean I just go to the store and buy 1-1/2" PVC connectors?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Hayward PVC plumbing
    If you want to use the female side (ie, screw the fitting into the pump/filter/etc.) you can use standard 1 1/2" threaded PVC. If you look at the yellow circle, you can see how my Hayward stuff connects to the hard plumbing:
    Some of the Hayward equipment has threads so that you can attach unions directly to the equipment. If you go that route, you have to use their proprietary union.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    I did.............NOT................ know that the hayward pumps used proprietary unions. There oughta be a law is all I'm sayin'.................
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by woodyp View Post
    1000% agree.
    The reason I know this is that I had a nipple screwed into my pump that started to leak. I figured I'd remove the nipple, clean the threads, redope it, then reinstall. Upon trying to remove it, I shattered the whole thing, couldn't get it out. Ok, forget it, I'll just use the other threads and install a union on the outside of the fitting. Could not find a union anywhere. It was in between every pair of sizes I found. Ended up buying the Hayward union from a parts supplier online. Fit like a glove.
    $10 for a part that should cost $3.
    Unbelievable.
    Apr 2010
    East Texas
    9,655
    Got a Hayward I'm fixing to install and glad I went ahead and ordered the 1/2 unions from them to match up. Thanks for the info.
    Pysiek's Avatar
    Apr 2012
    419
    Guys what unions are you talking about? Can someone post a link or something?
    My unit have female threads. The pump came in with two male connectors that you first screw in and the slip over the hose. I will snap a picture tomorrow after work and show you what I mean
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Quote Originally Posted by Pysiek View Post
    They may be talking about these .
    Love TFP? Become a
    TFP Supporter!
    Apr 2010
    East Texas
    9,655
    Yep, that' the animal zea3. Glues on to one end of a cut off PVC pipe and screws onto the threads of the pump intake and discharges.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by zea3 View Post
    Will they fit on 2" PVC?
    Why I cannot use this Sch 40 1-1/2" male connector ?
    Apr 2010
    East Texas
    9,655
    The threads are different.......coarse/finer.
    Pysiek's Avatar
    Apr 2012
    419
    Great. So now I will have to order the ones you guys showed me and wait till they arrive.
    Apr 2010
    East Texas
    9,655
    Different ones for 1.5 and 2" pipe sizes.
    Smykowski's Avatar
    Sep 2011
    3,065
    Give me 5 minutes. I'll take and post some pictures.
    Smykowski's Avatar
    Sep 2011
    3,065
    This is the union that is in the link that zea posted:
    1.5" PVC glues inside the one end, and the union nut screws onto the pump.
    This is the other fitting on the same pump:
    It was installed when I bought the house, so I don't know if it's a Hayward part or if it's standard plumbing. Male end screws into the pump, female end glues to 1.5" PVC. You can see the male threads on the pump, and you can put a union here if you want.
    The only other leftover fittings I have in the house (from the previous owner) are these, which I have in various places on my pumps and multiports. I think they're Hayward parts, because the part numbers stamped on them start with SP. Can't read the number on the straight fitting, too chewed up:
    If you want to do the unions on the pump, you'll just have to buy the Hayward part and wait. If you want to do it the other way, I'd just buy the parts from your local big box store and see if it fits. Then install standard unions and some type of valve (ball valve, pool valve, Jandy valve) to make maintenance easier in the future.
    Sorry it took so long, but I hope this helps.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Smykowski View Post
    The one on the right is what I have on both inlet and outlet. They just black. Also threads on both inlet and outlet are female threads. On the other picture it looks like someone have used the regular PVC fitting from local supply store. So it might work with mine then. I will have to go and visit HomeDepot after work. My 3 way valve will arrive today. One more question guys. My pool is semi inground pool. I put the filter on the high side and now the top of it (the part with handle to pump) is above pool water level. Will I have any problem with pump priming? Pump sits below water level.
    Smykowski's Avatar
    Sep 2011
    3,065
    No, it'll be fine. If the pump is below water level, priming will be no problem. Your pump looks plenty big to push the water up and through the filter as well.
    Keep us posted with how it goes and what you end up installing.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    One thing I would suggest is add a three way between the pump and filter. The perflex does not have a way to pump to waste. Spend the money at the pool store and get a good pool valve. Then you can vac to waste with that setup.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Pysiek's Avatar
    Apr 2012
    419
    I purchased this valve : Hayward valve as recommended by user on this forum.
    jcowart do you recommend to put it in between pump and filter? Can you explain this a little bit more? I have main drain that I want to control with the valve.
    Pysiek's Avatar
    Apr 2012
    419
    I will. I should get the valve today and maybe start working on it tomorrow. A lot of things I need to do. Run electrical , backfill the pool, build a deck
  20. Back To Top    #20
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Yes that is the valve. It would go between the pump and filter. The straight side would be from pump to filter. The other would normally stay closed. You can then put your backwash hose "normally blue vinal hose" on that side. When you want to vac to waste, open that side and it will close the filter side. With the bump type filter you do not use a backwash valve like other de filters.
