Results 1 to 9 of 9
Thread: Leak in return line for solar panels
    Dec 2012
    NorCal
    27
    Morning,
    I'm hoping someone has a suggestion on how to fix a leak in my pac return line from the roof. IT looks like it's a bad PVC weld because it is leaking right at the 90 angle on the ground.
    I don't think I have any room to cut in to replace the joint. Whomever put it in didn't leave much room between joints. They made a 90 to the ground, 2 45's right to give some separation from the solar panel feed line, about 4 inches of straight pipe , then a manual valve, another 4-5 inches of pipe and then a T for the bypass. I'll get photos tonite
    I'm wondering if there's a PVC safe putty like JB Weld I could use to patch? Any suggestions?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Leak in return line for solar panels
    Post a picture and somebody can tell you the best course. No good way but cutting it out. You may need to add a union to allow for the repair.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Self-fusing silcone repair tape works on water supply lines which are usually 60psi. You might give it a try. Just make sure the PVC is completely dry before you apply it. Also, it needs to be stretched while applying per the instructions to bond properly.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    Dec 2012
    NorCal
    27
    Photo attached. Leak is on the return pipe on the right hand side, on the side that faces the house. From what I can tell, it looks to be leaking from the joint.
    Dec 2012
    NorCal
    27
    It looks like it's been leaking a while and rusting the electrical conduit behind
    SW Indiana
    9,198
    If it was mine, I'd probably cut the pipe between the valve and the 45 and put a union there glued only on the valve end. Then cut the upright and remove the ell and 45 and replumb as needed to connect to the union.
    Jul 2013
    Waxahachie, Tx.
    442
    That's exactly what I would do also...unions in case you have to touch it again.
    Quote Originally Posted by JohnT View Post
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    Dec 2012
    NorCal
    27
    It's ok to connect without gluing? Now I'm wondering if the riser isn't glued into the 90.
    I guess if I got rid of the 45, I would have more room to work with
    Thanks for the advice, I appreciate it
    SW Indiana
    9,198
    Quote Originally Posted by Lummy View Post
    No, you need to glue eventually. Just that you need to start somewhere and the second half of the union is going to be connected to new plumbing. You won't know exactly where it goes until the union is installed on one side.
