Thread: Easy question - pvc fittings....
    Jul 2012
    Chicago, IL
    356
    I switched to flex pvc pipe last year from that cheap pool hosing and it works so much better... this year though I need a few things and could use some help.
    I use 1.5" flex pvc piping. Last year, on the suction side, I simply glued my flex pvc to the piece hanging down from the bottom of the skimmer, well when I winterized, I had to cut the flex pvc away from that piece (unscrewing with 20 feet of flex pipe attached was too difficult). After cutting, I unscrewed that piece and am left with a piece on the bottom of the skimmer that is threaded on both the inside and outside. Outside threads are about 2.5"
    I assume what I want here is a 1.5" (slip is it called?) to 2.5" union so I can re-glue my flex pvc to that and then simply screw on and off using the outside threads. I could not find this piece in the pathetic selection at my hardware store, so will just order, but what is it called?
    Additionally I need a few valves so I can shut things off without making a mess when it is time to clean the cartridge. There are many out there with a pretty wide range of price, any advice on that?
    Thanks!
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Easy question - pvc fittings....
    It sounds like you need a 2.5" threaded female fitting? You should be able to get that at a plumbing supply store, but usually big box and ace won't have 2.5". You can get reducer fittings to go from 2.5 to 2 and then 2 to 1.5...not sure if a fitting is made to go directly from 2.5 to 1.5.
