Thread: Bath mat for pool ladder
    Oct 2012
    Central Ohio
    180
    I'm not sure who 1st suggested using a bath mat as a pad under your pool ladder.Thank you who ever you are.I've used a bath mat under my ladder the last 2 seasons and it's worked out great. The mat doesn't curl up or float around.(the kind with suction cups on the bottom)
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Casey's Avatar
    SW PA
    10,438
    Re: Bath mat for pool ladder
    Cool! At least it works!
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Oooh! Cheap solution! I haven't put my new ladder in the pool yet because I was trying to figure out if I was going to use something under it.
    Problem solved! Thank you!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Casey's Avatar
    SW PA
    10,438
    Now all you have to do is pick a color or go with clear Beens. Decisions... Decisions....
