Thread: Doughboy with or without slurry in Texas
    May 2014
    Fort Worth, TX
    2
    I'm scheduled to get a doughboy Autumn Breeze 41x21 installed. The documentation I've found from Doughboy on below grade installation seems a little unclear on whether I need a slurry mix. My soil is very rocky and loaded with thick clay. I'll also have the 7ft deep end. I see where they recommend slurry for decking or concrete but I don't plan on either going right up to the pool. Also, because I have a pond about 50 feet behind my property, I wonder if a sump pump is necessary. Does anyone else here have a similar setup, soil-wise?
    Casey's Avatar
    SW PA
    10,421
    Re: Doughboy with or without slurry in Texas
    Welcome to TFP EagleMountain.
    Are you having the pool professionally installed? If so, I'm going to assume that the builder is going to provide everything needed to set the pool up according to the manufacturers instructions.
    May 2014
    Fort Worth, TX
    2
    I am getting the pool professionally installed but they are not using slurry for backfill. They told me that water accumulation under the deep end won't be a problem. I just would love concrete up to the pool but I don't think it will be possible without the slurry backfill.
