Thread: Salt water pool w/o swg
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I added salt to my pool (3200 ppm) but I'm not using a SWG, still using 3" pucks in a floater. (can't afford a SWG at this time). I've noticed that CYA levels should be higher (70-80) when using a SWG. Where should the CYA be if you have a salt pool but not using a SWG?
    Current results are:
    CL 3.5
    PH 7.6
    TA 90
    CH 400
    CYA 70
    Temp 88* AM - 92*PM
    CSI Index between varies betwen +.01 to +.06
    The water is crystal clear and there are no problems.
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Re: Salt water pool w/o swg
    Without a SWG you use the normal 30-50 CYA levels. Salt has no impact on the recommended CYA level.
    Butterfly's Avatar
    South Carolina
    10,045
    meatloaf,
    Just thought I'd mention that even tho the recommended levels for you are 30 to 50, many folks in your part of the country run a higher CYA level like you have.
    You're done SLAMing when:
