Results 1 to 10 of 10
Thread: Magnesium anode
    Louisiana
    127
    Magnesium anode
    I am about to install a new above ground pool but it will be semi inground. The pool is a Radiant Metric 27' round. These are built from aluminum with a foam insulation in between the walls. What kind of magnesium anode and where can i purchase to add to the install? Also when i bond pool does it have to be 18" away from pool and only 4 to 6" deep or can it be lower in ground and closer since i dug an extra foot around it and pool will be roughly 26" down in ground.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Louisiana
    127
    Re: Magnesium anode
    Was checking on an anode from a company and here is response.
    Anodes may help reduce the corrosion rate but there are other concerns for an aluminum frame in soil.
    Aluminum is an amphoteric metal meaning that it corrodes in soils with a low PH and at a high PH but has a low corrosion rate in neutral soils. I recommend that you have some soil testing completed to evaluate the PH of your soils as well as the resistivity of the soils. NCL does this soil testing for a cost of $69/per test/ per sample. If we have to collect the sample there is an additional charge.
    Also when you are saying bonding, are you planning on bonding the aluminum frame together or are you going to bond your grounding system to the aluminum frame? By bonding the copper grounding grid to an aluminum frame you are creating a mixed metal couple. This means that one of the metals will become the anode (aluminum frame) and the other will become the cathode( copper grounding) and will increase the corrosion rate of the anodic metal (aluminum).
    Is the aluminum frame coated? Coating reduces the amount of current necessary for adequate cathodic protection (CP). Coating is considered the first line of defense for corrosion with CP being supplemental corrosion protection. Without a coating the current required from the anodes will be greatly increased.
    If you would like to proceed with a soil testing and a design, NCL can provide you with a quote for soil testing, engineering, materials and installation if desired. Feel free to give me a call I am more than willing to discuss this further with you.
    TF 100 Kit
    Louisiana
    127
    Would you bond an aluminum pool?
    Not to highjack but . . .
    Split from your old hijacking location and merged into your existing topic. Please ask questions in your own topic, rather than hijacking someone else's existing topic. And never ask the same question in more than one place. JasonLion
    Would you bond an aluminum pool? Radiant Metric and was kinda told this. By bonding the copper grounding grid to an aluminum frame you are creating a mixed metal couple. This means that one of the metals will become the anode (aluminum frame) and the other will become the cathode( copper grounding) and will increase the corrosion rate of the anodic metal (aluminum).
    TF 100 Kit
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,868
    Re: another bonding question
    I can NOT answer a question definitively about a fence, but my own experience ( http://www.troublefreepool.com/threa...nd-around-pool ) says that it is more important when a person could be touching surfaces with different equipotential value at the same time.
    My advice is read and listen to the experts here and get it right the first time.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Magnesium anode
    You would probably be better off using the search function on the top right hand side.... Try searching bonding above ground pool....
    Here's one link I found....
    http://www.troublefreepool.com/threa...d-pool-bonding
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Aimee did you ever get your issue solved?
    Kpromero I am getting ready to bond an aluminum fence to the copper bond wire. I didn't have any concerns about dissimilar metals. Sounds like you're talking about something like galvanic corrosion. Hmmm
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Louisiana
    127
    I had emailed a company about a magnesium prepackaged with soil anode and that was some of his response to me. Maybe i am taking it wrong but it looked like he was telling me that bonding aluminum and copper together will result in the aluminum being the anode and will increase the aluminum to corrode.
    TF 100 Kit
    Re: Would you bond an aluminum pool?
    If the pool is permanently installed you don't have any choice, you must bond the pool, and you must connect copper to aluminum. If it is a temporary pool you don't have to bond, and shouldn't. The rules about exactly where the dividing line is vary somewhat from place to place.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I understand how that works from having owned boats, but usually you need high levels of salt to promote that effect. And the joint/area needs to be wet. Great, one more thing to consider. Now you're taking about your pool wall and the copper wire right? I'm talking about an aluminum fence, to copper wire. It will hardly be wet, vs your pall wall, which will likely be always/frequently wet.
    Louisiana
    127
    Re: Magnesium anode
    Thanks JasonLion and all. Just concerns me that he would say by connecting copper for bonding and attaching to aluminum that the pool would corrode more since it will act as an anode if i am understanding right and would like some of your inputs to see what i should do. Do any of you have this kind of pool and still bonded and no worries after years of doing? i want to make everything right on this one since it will be my second pool in 8 years and this one was not too cheap. Radiant Metric. Thanks
    TF 100 Kit
