Thread: Hot tub drained, pressure building, system not working!
    Oct 2013
    Phoenix, AZ
    25
    Exclamation Hot tub drained, pressure building, system not working!
    Hi everyone,
    ** edited **
    Disregard, problem has been fixed.
    Size of pool (gallons) = 15,000
    Pool Type: is IG (in ground)
    Construction: Plaster
    Filter type: DE
    Filter Manufacturer: SM/SMBW 2000 Series
    the size, model number or flow rate of the filter.
    Pump in HP = 2
    Pump is two speed
    Date of pool build/install = circa 2001
    with spa
    Oct 2013
    Phoenix, AZ
    25
    Re: Hot tub drained, pressure building, system not working!
    Filter type: DE
    Pump in HP = 2
    Pump is two speed
    with spa
