Results 1 to 10 of 10
Thread: Motor hums / buzzes, trips breaker
    Apr 2014
    USA
    25
    Hi everyone.
    I had a problem with the (now old) replacement motor of a Sta-Rite Dura-Glas II or Max E Glas II (What's the difference?).
    It happened only once so far.
    When the motor was powered, it hummed / buzzed for a couple seconds then tripped the breaker.
    I tested the start capacitor and run capacitor (microfarads). The start capacitor is in its operating range. The run capacitor is only 2% lower than its operating range.
    The shaft spins freely.
    What could it have been?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Motor hums / buzzes, trips breaker
    Welcome to the forum!
    Exactly how did you test the capacitors? Capacitor tester or ohm meter. And what was off by 2%?
    I believe those two motors use centrifugal switches which can get corroded over time. Try cleaning the contacts.
    Mark
    Apr 2014
    USA
    25
    Quote Originally Posted by mas985 View Post
    Capacitance test.
    The meter showed the run capacitor supplying 19.80 microfarads. It's rated for 20 microfarads.
    Thanks for the reply.
    Apr 2014
    USA
    25
    If it's not the contacts, what else should I look for?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Did you check the switch springs and make sure the switch is moving properly when the motor spins up?
    The symptoms point to the switch. Nothing else is intermittent like that.
    Mark
    Apr 2014
    USA
    25
    I'll check it out. Thanks.
    Apr 2014
    USA
    25
    If in time this happens consistently, is the motor fried?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Hard to say. Normally something like that can be fixed if you know what is causing the problem.
    Mark
    Apr 2014
    USA
    25
    If in the future this problem does happen consistently, is rebuilding this kind of motor worth it, or should it simply be replaced?
    Part of the reason I ask is because of the inconvenience of taking everything apart and/or taking it to a motor shop.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Again, it depends on what's wrong with it but also how much you are willing to do yourself. Even bearings can be replaced. About the only thing that is not worth repairing are the winding's. However, if you are going to take it to a motor shop, then you are probably better off buying a new motor. The pump wet end can usually last through several motor changes.
    Mark
