Results 1 to 8 of 8
Thread: How to add salt to the pool - "Bucket" method.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Here's my "bucket" method:
    Attachment 28887
    At the end: no salt going to the floor, everything gets mixed with pool water, no salt on pool deck, no sharp objects cutting salt bags close to the pool (liner).
    Just light pool sweep to make sure no salt sits on the liner.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: How to add salt to the pool - "Bucket" method.
    Way too much work! Pour the bag in, either aim a jet towards the pile or brush down the sides. There's no issues with the salt hitting the floor. They kinda look like diamonds...
    That is great.
    Of course just dumping an entire bag of salt in at one time is also fine.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    If I had a salt pool, I'd hold Diamond Day, where the bags of salt get poured in and the kids swim through it and scoop it up and throw it around and swim through the shower of crystals.
    A side conversation on adding salt through the skimmer has been moved here. JasonLion
    dnelson60's Avatar
    Mar 2014
    Humble, TX
    10
    I just pour a whole 40 lb bag in a 5 gallon bucket, put it on a step that allows the top of the bucket to be lower than the water level, stick in
    a garden hose and turn it on. Takes about 5 mins to dissolve it all. Except for rain, the only time I need to add salt, I also need to add water,
    so it works for me. Even if you don't "need" to add water, 5 mins of a garden hose doesn't hurt anything.
    21,000 gallon SWG free form pool, Pentair cartridge filter, Pentair 2HP Whisperflo pump, Pentair 400K btu heater, 400 gallon spa, Circupool si45+, Dolphin Oasis Z5 cleaner
    38,271
    I am failing to see why a bucket is needed at all
    Why don't you just dump it in the pool? Is there some misconception that the salt will damage something?
    I walk around my pool dumping 100s of pounds of salt in and it is mostly dissolved by the time I make a lap. A couple minutes with a brush and it is gone ... and that is not even required if I wanted to be lazier.
    Ukie's Avatar
    May 2012
    Export, PA
    83
    No misconception at all. Just alternative method how to mix solids with water.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    38,271
    Quote Originally Posted by Ukie View Post
    In context outside of salt, I could see some value in using this method. Although many solid powders can also just be thrown into the pool without worry.
    This contains the methods we recommend adding various chemicals: Recommended Pool Chemicals
