Thread: want to up upgrade for intex pump/filter
    May 2014
    New Mexico
    21
    we have a Intex 15 x 48 pool the pump/filter it comes with is only 1000 gph how much bigger can I go and have the pool still stand upright. I have found a 2500 gph pump/filter was thinking or getting this one. any input would nbe GREAT.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: want to up upgrade for intex pump/filter
    Welcome to tfp, goats
    Many people have had great luck with the intex 2650 sand filter. Your pool should be fine with the higher flow rate.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Make sure the pump & filter your buy comes with the large fittings. many sellers are not including them in their "upgrade" packages any more. Don't try to use these adapters, they will slip off and spray your pool water everywhere.
    If you buy the upgrade package, these should be included.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I had the intex 1600 with a summer escapes 15' x 42" and it did an excellent job.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
