Results 1 to 7 of 7
Thread: Went on Vacay, came back to green pool!
    Bobbystone
    Guest
    Hey Guys,
    I just got back from a weeks vacation in the islands, all psyched about getting the pool fixed up for the summer. To my surprise there was some green scum on the steps and the water is just a tinge green. I tested the Salt and CYA and everything was pretty much wiped out from all the rain and storms we've had over the winter. So, I've topped off the salt and CYA, will wait to adjust PH after the CYA is dissolved. Do I need to shock this pool? Or will adding the salt and letting the salt gen work more hours clean up this mess? Thanks in advance for your help! You guys are great!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That's a bummer. You'll need to SLAM the pool. For this process turn your SWG off. What CYA level did you shoot for when you added it ? That will determine your SLAM level FC.
    Here is the SLAM process. Read about it and follow it to the T. You will be using bleach for this process. Do you have one of our recommended test kits ? You will also need one for the SLAM process. 😎
    http://www.troublefreepool.com/conte...tain-shockingl
    Can you post a set of test results ?
    Jeff
    Bobbystone
    Guest
    Re: Went on Vacay, came back to green pool!
    Thanks of your reply. Should I wait to add CYA until after I SLAM? Here were the numbers I just got:
    I have the Taylor Pool Test kit. Do I need something different or will it work?
    FC .01
    PH 8.0
    TA 90
    CH 260
    CYA didn't read.
    Thanks!
    Bobbystone
    Guest
    Sorry also tested TC and CC CC = 0
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Nope. Adjust pH and assume the CYA you added is there and start dumping bleach to get to the appropriate level for that CYA. If the pool is green and there is no CYA, the excess will get used up long before it can damage things.
    Bobbystone
    Guest
    One thing.. When I got back the skimmer baskets were pretty clogged with pollen. Is it possible that the gunk is pollen that hasn't been filtered yet? I didn't really show any CC after rI added chlorine. Should I try the overnight test and see what happens? Thanks again for all the help!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can do the OCLT, but in your first post you stated the water had a green hue and algae on the steps.
    Get the skimmer baskets cleaned out.
    Jeff
