Thread: Spa Motor not working - Balboa power pack
    Spa Problem - motor
    I have a Balboa spa pack. the 2 speed pump is not working but the 1 speed pump - pump 2 - is working fine. what i have done so far is changed the capacitor and checked the voltage to the pump. I have all voltage to the pump as perfect. here is another issue. In order to see if the pump was working, i took the wire on the spa pack that says pump 2 and switched it with pump 1. when i did that, the 2 speed pump came on when activated at the control panel.
    so i know the pump is good, the control panel works fine for everything. the red dot even lights up when pump 1 is activated, its just the pump doesn't come on.
    I could really use some tips here from you guys that have more experience. i am pretty fair with DIY and using volt meter.
    Thanks in advance for everyones help.
    Harold...
    Sharkline Matrix 24' x 54" Round AG Pool,
    Pentair Sand Dollar SD60 Sand Filter System with 1-1/2HP Dynamo,
    15,000 gallons,
    Intex SWG CS8110
    T100 test kit
    Pump runs 10am to 10pm
    Pool in sun 24/7 - lower Alabama
    38,303
    Re: Spa Motor not working - Balboa power pack
    Sorry you did not get a response yet.
    Sounds like both 2-speed and the single-speed pumps work when connected to switch for the single speed
    Did you hook the single-speed pump to the switch for the 2-speed to try that?
