Thread: White thermometer turns pink
    Question White thermometer turns pink
    Okay, this is weird.
    Purchased a new white plastic thermometer and immersed in the water and the plastic turned bright pink. This also happened partially on a white bag I was using with my pool skim.
    Numbers:
    PH=7.6
    FC=5.5
    TA=70
    CC=0.0
    CH=250-300
    CYA=30
    Just started heating pool yesterday. Pool is basically clear with some minor powdery debris. Filtering, brushing and running robot about 10 hours per day to clear.
    Thanks for any help!
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    30,431
    Re: White thermometer turns pink
    That is really surprising. Plastic finishes are normally quite stable.
    Your numbers look quite good and I would say your pool water had nothing to do with the change.
    Many thanks, Dave, I'll probably do an overnight on the chlorine just to make sure.
    Regards,
    Gary R
