Thread: Hayward Xstream cover will not tighten
    May 2014
    United States
    2
    Hi all, I have had my hayward Xstream filter for four years. I am having an issue where the black locking ring binds before it is fully locked. If I force it it becomes welded on and is very difficult to remove.... Has anyone had this issue and is there a fix... I tried cleaning threads with toothbrush and soapy water...
    Re: Hayward Xstream cover will not tighten
    I have the exact same problem - used the toothbrush and detergent on the threads for the base and the locking ring, ordered a new O-ring, and made sure to apply Jack's lube. It still won't tighten down to where it 'clicks' - it binds up before the click. Very frustrating!
    WendyNat
    Va Beach
    18' round, 52" tall above ground pool
    2 speed cartridge filter
    May 2014
    United States
    2
    So far the hayward response is replace o ring and install cover straight... Oring done no change and I am pretty sure it's going on straight given that it worked fine for four years... More to come
