Results 1 to 9 of 9
Thread: Time to open?
    Time to open?
    Morning everyone, I have a intex above ground pool that I left up all winter. We are in southwest Missouri and the forecasted temp today is 85 and looking very warm for the rest of the week. Just kind of curious when I should open this sucker up . This is my first year of having it up all winter. I know algae can be a problem if it get's very warm, Correct? Any advice greatly appreciated
    Thank you
    Brian
    Intex 16X48, Intex sand filter, Game 3/4 HP pump. Springfield Mo
    Re: Time to open?
    You want to open the pool before the water temperature gets to 60 degrees. Generally by the time the air temperature is 85 the water will already be 60, though that varies depending on what kind of weather you have been having.
    Re: Time to open?
    Thank you, We have had a very cold nasty winter and several cold mornings. This is the first time of the year it has gotten this warm. I think I will plan to open very soon then.
    Brian
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Time to open?
    I would open it up now and get things going. Algae likes it when water temp's hit 60. Not that it can't form below 60.
    Test your water and get things balanced. I hope you have one of our recommended test kits and if you don't, do yourself a favor and invest in one.
    If you need some advice on the water chemistry post a set of test results and we'll help ya out. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,446
    Re: Time to open?
    Open the pool!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Time to open?
    Open it up now. Then be a smug self-satisfied jerk to your friends and neighbors when they complain about their green swamps in a week or two.
    Re: Time to open?
    Thanks guys! I did open it today and good thing I did, it was starting to get some algae on the side where the water line was. Pool temp was right at 60, I shocked the **** out of it and cleaned pump is running full power ahead!
    Now if I can keep the **** birds off of it, I think they were use to the winter cover and they liked to bath in it, Now they just sit on the edge and **** any ideas for this?
    Casey's Avatar
    SW PA
    10,446
    Re: Time to open?
    A plastic owl may help.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,092
    Re: Time to open?
    We use plastic snakes around the pool. Keeps birds away and gives the kids the tools to play gags on their unsuspecting friends.
