Thread: Cleaning Pool Surfaces
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Does anyone know if Clorox CleanUp actually has bleach in it? Will it affect pool chemistry?
    What are you trying to clean up?? There might be better options for you...
    You can look here for the MSDS sheets (scroll down to the clean-up products.) All three contain bleach.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Wow. Bleach AND Lye. Cool.
    Actually, in this case, I'm looking to clean the inflatable ring (donut) of an 18 foot Intex above-ground pool. It gets dirty and gritty from living under an oak tree, and it seems that the local blackbirds and blue jays like to party there too.
