Results 1 to 8 of 8
Thread: am I in to much of a hurry
    Jul 2011
    Terre Haute indiana
    60
    fc 21 cc 2 ph 7.2 ta 140 cya 50 winter cover split and went into the pool this winter with everything on top now in the pool, used the net to get out as much as I could. Went with turning your green swamp sticky and it went from a dark green, almost black to a cloudy light blue in just a couple of days(started last Tuesday), haven't seen any difference in the last couple of days. Not able to see the pattern on the liner floor even in the shallow end. Adding about half a gallon liquid chlorine a day to keep fc at shock level. Am I trying to go to fast to clear this up or is this normal for as bad as it started out
    19500 gal, IG, haywood s-200 sand filter & pump, 3/4 horse single speed motor, vinyl liner, tf 100 test kit, installed early 80's, Terre haute,In
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I think your on track. As long as your keeping FC at SLAM level as long as you can and running pump and filter 24/7, backing washing when pressure rises it'll come around. Make sure your brushing also. Usually in the beginning you see quick changes then things slow down a bit. That's where the POP comes into play.
    Also having a sand filter will take the longest to get it back to crystal clear. 😎
    Jeff
    Casey's Avatar
    SW PA
    10,444
    Re: am I in to much of a hurry
    Your sand filter is going to end up doing most of the work and as pwrstrk said, they take the longest to filter it out. Give it time and keep SLAM'ing the pool. Brush it too!
    Jul 2011
    Terre Haute indiana
    60
    thanks guys, thought I was rushing it, you know my filter is around 30 years old, still working several leaks, thought about get a new one before this goes complety. are the DE filters really as better as talked out and are the hard for a old dog to figure out
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    All the different types of filters will do the job. The main thing with keeping clear water is maintaining proper water chemistry. Having your FC in the proper range for your CYA level will go along way in having clear sparkly water.
    As for the types of filters everybody has their preference one type isn't really any better than the others. With DE you have to mess with DE or a DE alternative. Cart filters you don't back wash, you have to break it down and wash the filter out. Sand filters you already know about. I have a DE and I'm happy with its performance.
    Jeff
    Jul 2011
    Terre Haute indiana
    60
    thinking I'll stay with a sand filter if I have to replace this one, its done the job all these years. thanks for your help and advise
    Jul 2011
    Terre Haute indiana
    60
    Made It, two weeks and a day from nasty green slime to clear water, passed overnite test less than 1 part drop fc, cc.5 ph 7.6-7.7, ta 120, ch 190 and been reading cya as 50 but I think its closer to 35, while slaming used a lot of chlorine during the day , a lot less at night to keep fc levels at 20-22. Had some 3 inch tabs so I put 3 in to raise cya some more will check daytime fc loss in a few days. thanks for the help and the green swamp sticky note
    30,421
    That's a long SLAM! Kudos to you for staying the course.
