Results 1 to 17 of 17
Thread: Very high chlorine
    May 2014
    Mesa, az
    8
    Very high chlorine
    Hi all, I just bought a house that has a pool, my first one. I have been reading on here and got my TF-100 yesterday. So I did my FAS-DPD test and got a crazy high chlorine level, like I stopped adding at 100 drops. It never got clear but it did stop changing color at a lemonade like yellow/white after about 50 drops.
    I tried doing some other tests but they didn't really come out either, guessing because of the high chlorine.
    Just to be sure I was doing it right I did a Taylor daily test and the water turned like red I will try attaching a pic.
    The water is clear and the pool looks fine I am just wondering if it is okay that the chlorine is that high? Also should I just let time run it's course to lower it or should I dump water?
    15k guessing, IG, plaster, sand filter, 1.5hp century centurion, built 1986.
    38,305
    Re: Very high chlorine
    Welcome to TFP!
    Can you post the full set of test results?
    Did you start the FAS-DPD with 10 or 25ml of water? How much powder did you use?
    38,305
    To elaborate more. The water does not have to go clear, it should mostly, but you are always looking for the point where adding more drops does not change the color.
    I am guessing you FC is in the 20s, which may not be too high depending on your CYA level.
    Oh and no need to dump water. It will come down.
    How did it get so high?
    May 2014
    Mesa, az
    8
    I used 10ml and a heaping spoon full.
    I am assuming some of these test results are off but I got
    Cya- 90
    CH-200
    PH-7.8
    May 2014
    Mesa, az
    8
    I have no idea how it got that high, I am guessing the previous home owner just dumped a ton of chlorine when they left to keep the pool from going green (which can be a pretty big ticket out here if the police chopper see's it from what I here).
    Casey's Avatar
    SW PA
    10,448
    When did you take possession of the house and pool?
    May 2014
    Mesa, az
    8
    I got the keys last week and never added anything, but there was a floaty in there. I have since taken that out, I think the house was vacant for about 7 weeks but someone had to be taking some form of care of it.
    38,305
    Well. Time to start looking forward.
    How did you do the CYA test? What kind of lighting? If it is that high, the first step will have to be replacing water.
    They must have recently refilled the pool for the CH to be that low in AZ. Too bad they used all those tablets (and likely Dichlor powder chlorine) and got the CYA so high.
    May 2014
    Mesa, az
    8
    Yeah that was what I was afraid of, But oh well what can I do. I did the test I the early evening, sun still up. I will retest in a day or two as we don't live in the house yet.
    Jan 2012
    'burbs of Augusta, Georgia
    7,357
    Quote Originally Posted by KWin View Post
    what does this mean? The police ticket you if you let your pool go green??
    May 2014
    Mesa, az
    8
    That's what I understand if the chopper flies over and they see it green they can cite you for a code infraction. I suppose it's the same as citing you for an overgrown yard or a car parked in your yard. But for the money it costs to fly those things you would think they had something else to do.
    Would I have to lower the CYA? Or can I just live with it like that? Is there any detrimental effect to it being that high
    38,305
    The higher the CYA, the higher the FC level you must maintain. See the CYA/FC chart in Pool School.
    As long as no algae starts, you may get by with the high CYA.
    May 2014
    Mesa, az
    8
    Just wanted to update and get your guys opinion. So we moved into the house, and I have since retested for everything. I have added no chlorine yet so about 4 weeks and the tests are getting better so here is how she sits today.
    FC 22 to the lemonade color won't go clear
    Cc 0
    Ta 150
    CH 330 never really gets red but turns dark pink
    Cya just below the 100 graduation.
    Ph 7.6
    So I really is just wondering what you guys think. Also it's been 4 weeks and the chlorine is still in the twenties should it take this long to come down?
    Also the pool needs major work soon, new waterline tile and a plaster job, although I will probably go pebble sheen. And waterline tile. Can I get away with these numbers through the summer. I was thinking of just keeping FC at about 17 with my CYA sound okay?
    Your CYA level is a lot higher than you think it is. The CYA test will report anything over 100 as 100, so who knows how high it actually is.
    By the time you get the CYA level down to something reasonable, the FC level will come down.
    Also, with FC that high you can't use the PH test, so ignore that PH result and retest PH as soon as FC comes down below 10.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I know everyone hates pool stores but if you have one close and this is your first pool and first time testing I'd take a sample in just to compare. Seems odd the FC is so high and you haven't added any chlorine. I think your FC target with a CYA of around 100 would be 12.
    The numbers seem to be at the high limit but acceptable if you didn't want to try and put them more to the middle of the range.
    Jason, would you suggest dumping about a quarter of the pools water, refill and retest the CYA ??
    Solar Blanket, Well Water, Borax Added. 68
    Quote Originally Posted by kiss4afrog View Post
    I would start by doing the CYA test with dilution: mix equal parts of pool water and tap water, do the CYA test with that, multiply the result by two. That will tell us if I am correct or not. If CYA is really well over 200, as I suspect, way more than 1/4 of the water will need to be replaced.
    May 2014
    Mesa, az
    8
    I will try the dilution test for cya. Hopefully I can just sneak the pool through the summer then drain it and have the remodel done.
