Results 1 to 8 of 8
Thread: New water fill after liner replacement
    Sep 2013
    Charlotte, NC
    41
    Cool New water fill after liner replacement
    Hi
    After so many issues, I finally replaced the liner, pool should be filled by tomorrow morning.
    I just want to make sure as what do.
    1- Test Water
    2- balance water according to pool calculator
    Run pump for......24 hrs??
    I'm thinking that's what I need to do. Please confirm and correct if needed.
    I would like to add borates to the pool. I read the thread, do I do this now or later?
    Thanks for the help.
    26K gallons, IG vinyl, Pentair 1.5 HP, Hayward DE filter, TF 100 test kit, Ecojet Turbo Cleaner
    Re: New water fill after liner replacement
    You have the right idea.
    Adjust your other levels first, before tackling borates.
    Casey's Avatar
    SW PA
    10,423
    pH
    CYA
    TA
    Borates
    Sep 2013
    Charlotte, NC
    41
    Test Results
    TA 20
    CH 50
    PH 6.8
    Sep 2013
    Charlotte, NC
    41
    Hi quick question.
    Pool calculator said 138 oz of CYA, but according to pool school use only 1/2 to 1/3 of the amount called for.
    I put 60 oz in 2 socks by the returns.
    My ph is 7.8
    TA is 40 after I put the soda ash.
    Should I put baking soda to increase TA?
    I input CYA amount into pool calc to see how much would it increase it says 17.
    Should I put more now? Or wait a week and see what result comes up to?
    I wanna put the chlorine soon, it's hot here, we already hitting 87-88F I want to make sure I put this in ASAP.
    Thanks"
    30,403
    You should put in the amount of CYA that will get you to 40 ppm (total) and then forget about it.....don't retest.....assume it is in there
    You should put your FC in now just like you want to do.....enough to get to 5 ppm or so. retest and add more daily to keep FC around the 3-5 ppm mark.
    Can you tell us what article in Pool School says 1/2 to 1/3 of CYA? That needs to be changed.
    Sep 2013
    Charlotte, NC
    41
    I will look for it and tell you. I have the bookmark in my home PC.
    TA I should not worry about it right now?
    Thanks for your quick reply.
    30,403
    Forget TA until later.
