Results 1 to 9 of 9
Thread: 2.5 Gallon Chlorine Carboy - spout?
    Apr 2014
    Venice Florida
    24
    Anyone have any good idea for pouring fro 2.5 gal carboys without spills.
    It seems someone would have invented a spout that would screw on these containers
    and allow for pouring out into a measured bucket without leaks and splats.
    Pool home in Venice Florida. No pool home upstate NY. Retiree from Navy Nuclear Power Design Laboratory.
    9500 gallon plaster pool. cartridge filter, pentair vs pump, fafco solar heater.
    New to the pool thing. Learning.
    Part time requires a pool service for pool maintenance.
    22,548
    Re: 2.5 Gallon Chlorine Carboy - spout?
    If it has a standard 38mm cap you can find faucets here. If it's a non-standard size you can get a bulkhead faucet and install it in the cap yourself.
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    I have 5 gallon carboys and I've been using a cheap $2-$3 hand siphon I got from the hardware store.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    Orlando, FL
    690
    I know this thread is old but does anyone have any other ideas? I am tired of pouring chlorine on my foot when filling the Liquidator.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    22,548
    You could buy a syphon/transfer pump like shown Here. Since it's all plastic it should hold up to bleach. I'd probably rinse it out after each use.
    Orlando, FL
    690
    Thanks Dave. That is exactly what I need.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    Just out of curiosity, where do you store the carboy and how fast do you go through it? Bleach is heat and light sensitive, right? I would love to find a better solution for my routine. Currently I just keep a gallon in a bench box with a plastic cup I use for measuring.
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I use an old Clorox bleach jug. Cut the bottom off and you have a big funnel with a handle.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    domct203's Avatar
    Jun 2015
    CT
    3,581
    Quote Originally Posted by mikespoolfl View Post
    Darn, beat me to it
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
