Results 1 to 7 of 7
Thread: Chlorine Stick In Light Niche?
    ChuckDavis's Avatar
    Aug 2010
    Durham, NC
    77
    In the past algae has found my light niche to be a cozy little hangout. After installing a Liquidator last fall, I have some leftover chlorine sticks. Would it work to put a chlorine stick in the light niche periodically to make the niche a little less hospitable to the algae? (I have a zinc anode attached to the light.)
    15,000 gallon IGP, epoxy surface, waterfall, borates (!), not closed in winter
    SuperPump with 2.4 THP EcoTech variable speed motor, Tagelus TA-60 filter with zeolite media, Liquidator, AquaComfort heat pump, Blue-White flowmeter, Smartpool Wall Climber
    TF-100, LaMotte metal sequestrant test kits
    Sundance Capri hot tub
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Chlorine Stick In Light Niche?
    While I don't know for sure, I'm going to guess that's not a good idea. You would be making a very small area with a small volume of water VERY acidic. If you're concerned, either disconnect it and clean in every once in awhile, or use a hose to flush it out. Ideally if the rest of the pool is properly chlorinated, it would be very difficult for algae to find its way down and back there.
    ChuckDavis's Avatar
    Aug 2010
    Durham, NC
    77
    In the past I've scrubbed the niche and poured liquid chlorine behind the light using a funnel and short length of hose while SLAMming. The niche was the reservoir for the algae. I was hoping the chlorine stick could be used as a preventative. Oh well.
    I would definitely recommend against putting a trichlor tab or stick behind the light. It would damage the light, cord and niche.
    Support the site
    Casey's Avatar
    SW PA
    10,453
    Agree.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    +1 to no chlorine stick in the light niche. Having chlorine that concentrated in such a small area with virtually no circulation would be highly corrosive.
    Love TFP? Become a
    TFP Supporter!
    Aug 2013
    Mansfield, Texas
    72
    Just took my light out thinking there was algae behind it. Long story but I couldn't get my light out at first so I used the hose from my vacuum, disconnected from the vacuum of course, and blasted water all around the edge of the light. I did this three days in a row while slamming. The first two days junk came out from behind the light. The second day I did that until nothing came out. The third day nothing came out at all. I got the light out on the fourth day and the niche was nice and clean. I would guess if you did this once a month or so it would keep the niche nice and clean.
    15,000 gallon plaster pool with spa and water fall, 250 Pentair MiniMax Plus Heater
    Nautilus FNS FIberglass D.E. Filter 48 Sq ft, Leslie's DPD Complete Chlorine Kit + TFTestkits Chlorine & CCs Kit.
    Oak trees overhanging most of pool
