Results 1 to 7 of 7
Thread: Chlorine produced by Hayward T-CELL-15
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I can't find any technical doc from Hayward explaining how much chlorine is produced by the cell per hour of runtime or whatever. I can't find any info, so trying to calibrate % output for my 8 hr daily run-time is a guess. Granted over time I can figure it out, but I'd like to know. Does anyone have this info, or know where to find it?
    Thanks
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Re: Chlorine produced by Hayward T-CELL-15
    At 100% it can produce the equivalent of 1.45 lbs of chlorine gas in 24 hours. You can use Pool Math to figure out what that is equivalent to.
    Oct 2013
    Chapin, SC
    1,141
    So, Jason, correct me if I'm wrong. The math for my si-45 is 2lbs/ 24 hs@ 100% comes to 32oz. And if I run it for 6 hrs@40% , plugging that into pool math for my 24k pool, that comes to 1ppm generated/ day. And if I want to see what the sun or organics is burning up per day, i shut off my cell and discover my fc is decreasing 1ppm during the last 24 hrs I've essentially figured out how to get my fc to 5ppm from 8ppm is to turn off my cell for 3 days so, tomorrow, I need to turn it back on so it doesn't get any lower.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Quote Originally Posted by JasonLion View Post
    Thanks Jason. Did you find this somewhere, or did you just happen to know it somehow?
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    So if my math is right, I get 1.45ppm FC in an 8 hr period at 60%.
    lbs Clorine Gas in 24 hrs @ 100%: 1.45
    Oz. Chlorine Gas in 24 hrs @ 100%: 23.2
    FC per 24 hrs for 24,800 gall pool: 7
    Run Time (hrs): 8
    % Output: 60%
    FC ppm generated per Period 1.40
    So sounds like I need to figure that out too timerguy, FC lost per 24 hr period, and make that up with my run time! Cool. up until now I've felt like I was just guessing on run time and % vs usage...
    "Guessing" as you call it is the best approach. Doing math as you have been doing above can get you a good initial approximation, but the actual percentage required will vary over time. Once you are at all close, the best approach is to turn up the percentage when FC is low and turn down the percentage when FC is high.
    Hayward advertises their chlorine production numbers fairly prominently. Some of the other brands numbers are more difficult to locate, though almost everyone lists it somewhere. This chart is a good place to start. They list a lot of brands/models, though not everything.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Thanks a million! I looked at the pages for the turbo cells on Hayward's site but couldn't find it. Once I knew what I was looking for, Google found it for me on their AquaRite pages.
