Thread: New pool owner - no suction at skimmer - various other questions
    May 2014
    Brampton, Ontario
    2
    Hi All,
    I bought a house with a pool in December, and it was just opened today, but I have a few questions/issues. It's a 16x34 with SWG, solar heating, Sand filter. There is no bottom drain, just a skimmer on one side, and a downward angled pipe on the other side.
    First question is regarding the skimmer, there is no suction. I am not sure if the line is clogged, or if it was just not opened properly? I took a look and there are 2 holes at the bottom, one seem to be plugged, and no suction from either
    Second question is regarding the Jandy valve position, and may be related to the skimmer. What position should it be in?
    Also, the pressure gauge on the filter seems to be pegged. never changes, even when pump is off, and gauge is disconnected.
    Third question would be regarding the actuator for the solar panels. what position should it be in? It's a Pentair, control panel says Compool Lx220. on the actuator there is an On1, Off, On2 selector switch.
    Pics attached. Any help you can give would be appreciated!
    Skimmer
    Other side, not sure what this is for?
    Solar Actuator... what position?
    Jandy Valve... what position?
    https://dl.dropboxusercontent.com/u/...Pool/Jandy.jpg
    Gauge?
    Thanks!
    Re: New pool owner - no suction at skimmer - various other questions
    Welcome to TFP!
    The pressure gauge is broken, and should be replaced.
    The solar valve is currently in the 100% of water goes to the solar panels position. Turn it 180 degrees to prevent water from going to the solar panels.
    It is tricky to figure out the skimmer no suction issue without more information. Is the pump strainer basket full of water? And it would be nice to know the filter pressure when the pump is on (when the gauge gets fixed).
    May 2014
    Brampton, Ontario
    2
    Thanks for the quick reply!
    How about the Jandy valve I just guessed the current position. I tried all positions, I put the handle to the right, and there is no flow on the pump. In the middle or to the left and it works. I'm thinking one side is the angles tube inlet, other side is skimmer, and when I put it to the left it is only skimmer which is not working, so thats why no flow through the pump?
    Quote Originally Posted by JasonLion View Post
    Welcome to TFP!
