Thread: spot tiles
    Apr 2014
    la
    3
    spot tiles
    I want to install 1x1 glow in the dark tile inside the pool. can I do this after the plaster work was done. I was thinking to sand the spots and lay each tile, then seal it with grout. can this be done this way. I want to do it my self the contractor is charging a lot
    30,421
    Re: spot tiles
    Welcome to the forum.
    That won't work in any manner I can think of. I can't exactly picture where you are putting these tiles but I think you will be unhappy with the results.
    Apr 2014
    la
    3
    Re: spot tiles
    I am spreading them out so it would look like stars at night time.
    Apr 2014
    la
    3
    Re: spot tiles
    take look at this photo, I don't want this many but this is the idea. thank you for your comments.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: spot tiles
    Welcome zrang!
    You must do this when or before plaster work is done. Preferably prior to plaster but during the process at minimum. Otherwise, there is not a good way to install and attach them.
    Essential Links:
