Results 1 to 7 of 7
Thread: CYA test discovery
    Fort Worth, TX
    83
    CYA test discovery
    I've been having fits testing CYA ever since I've been doing BBB.
    I never felt good about the readings and thought the test was too subjective.
    I finally broke down and bought the standardized 50ppm sample.
    I've been playing with it all afternoon and found that if I hold the test beaker at chest level, rather than waist level, I can nail it every time.
    When I did it this way with my pool water I found I have about 25-30ppm rather than the 50 I thought I had.
    I've been using more chlorine than seems right. I'm going to add about 2 lbs of stabilizer this afternoon.
    You might find you need to test at waist level, under your chin or down around your knees. It depends on your particular vision.
    I highly recommend getting the standard solution. It will show you the right way to test...IMO
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    38,267
    Re: CYA test discovery
    I am not sure it has as much to do with your vision as it does with the intensity of the light you are in.
    Thanks for the observation though.
    I just got some of the standard solution as well, but have yet to experiment.
    Fort Worth, TX
    83
    You may be right about the intensity of the light.
    Whatever it was, holding the test beaker about 8" under my chin worked. Holding it at waist level didn't.
    I wouldn't have known that without the solution.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    What is this "standard solution" you both speak of?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Ah I see. It's more to "calibrate" your own testing with the real regaent?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Yes. It is to show you what you are looking for.
