Thread: Something wrong with FC level?
    Apr 2013
    South California
    69
    I just opened the pool yesterday. The pool had been covered all the time it's been closed.
    FC: 0
    PH: 7.5
    TA: 110
    CYA: 80
    SALT" 3000
    Water is clear
    After I measured yesterday, I added 24oz of chlorine. Today, I measured again and FC=0. Added 24oz of chlorine. Checked back after 45min. FC = 1. Added another 24 oz.
    During the closed time, once in a while I ran the SWG. Is something wrong here?
    Since yesterday:
    I added a 5 lb of salt to bring up to 3200 ppm
    Been working on bring down PH. Adding acid to bring PH and TA down. Today TA = 100. Keep adding acid and doing aeration.
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Re: Something wrong with FC level?
    Having a little extra chlorine demand when you first open in the spring is fairly common. I suggest bringing the FC level up to around 10, and then do an overnight chlorine loss test just to make sure you cleared out whatever is causing the excess chlorine demand.
    Apr 2013
    South California
    69
    Thanks Jason. I will add more chlorine right now.
    Can we get into the pool during the process?. The kids keep asking all day.
    Installed 4/29/13
    If you can get FC up to 6 or higher then swimming is fine.
