Thread: Smelly pool water
    Smelly pool water
    I have an above ground pool 18 foot circular, 48 inches deep. never had much of a problem with the pool for the past 8 year but this year sudddenly the wayer smeels bad. it has a strong metallic oder. I did have the water tested and they said it's perfect, yet the water is a little cloudy and green and ofcourse the smell is bad. I have vacuumed to get the algae out. But even in the past with algae I never had an issue with my pool smelling. Any ideas?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Smelly pool water
    You'd need to post some test results for answers that are more than guesses. Cloudy, green water says the water chemistry is wrong. Pool stores in general don't know anything about maintaining pool water.
    well I took a sample up to leslies
    Free avalible chlorine 2.0
    Water PH 7.6
    total alkalinity 100
    calcium 150
    cyanuris acid 60
    no idea what it could be. I do have some powdered chlorine that got wet, I have been using that. not sure of that could be causing the problems or not.
    It's not really green as much today, a little cloudy which can be cured with some clearifer. The smell seems a bit better but still there.
    SW Indiana
    9,199
    With your CYA at 60, you need to maintain a higher FC level to keep the pool sanitized. Richard's chart in Pool School at http://www.troublefreepool.com/category/pool-school/ recommends a minimum chlorine level of 5ppm at all times, and a shock level of 24ppm. If you raise your FC to at least 15ppm and hold it there for a few days, you should see a noticable improvement in your water quality.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by Hammy
    Do you have a pool frog or a Nature 2 pool sanitizer...They add metals to the water as a way of sanitizing...that could be the cause of the metallic smell...Also the green could be from the copper...have the water tested for copper if you have either one of these itmes running on your pool.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
