Results 1 to 10 of 10
Thread: Algae and CYA Problem
    May 2014
    pa
    5
    27'AG 48" Tested CYA I have a reading around 100. Been checking the site appears from my research that the best thing to do is to drain it half way and refill. I have a frog chlorine dispenser. Should I use it after I get everything in check?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Algae and CYA Problem
    Is that frog the mineral based sanitizer? If it is, you should really pitch it. As far as you can!
    Just to make sure your CYA isn't actually higher than 100, dilute you pool sample 1 to 1 with tap water, and retest. Then multiply the results by 2 to get a close estimate of the true level.
    May 2014
    pa
    5
    It is mineral base can u explain? When I start with bleach or liquid chlorine I will just add it daily into the skimmer?
    Smykowski's Avatar
    Sep 2011
    3,065
    The Pool Frog has two parts. The Bac Pac is trichlor, plus a mineral cartridge that puts God knows what in your pool. Stopped using mine years ago and finally ripped the whole thing out last spring.
    Have you read pool school yet? Start with the link in my signature.
    May 2014
    pa
    5
    Just did thanx. I'm learning a lot mostly how I have been getting pool store for the last two years
    Casey's Avatar
    SW PA
    10,450
    The best part is that you'll never have to be pool stored again.
    If you haven't already, purchase a TF100 XL. It is the best test kit out there. And check out the speed stir while you're at it! It's pretty cool!
    Drain and refill and retest the pool water. Post results and we'll help you get a hold of your pool water and maintenance.
    Did you kill that frog yet? Seriously... get rid of it!!! All it will do is stain your pool liner and turn every beautiful blonde haired beauty that enters your pool green!
    May 2014
    pa
    5
    Ordered the kit, as of now the calculator advises to drain 60% of my water. The pool store near me has free water testing I'll let you know the numbers. Took out the frog its empty.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Free water testing is worth about what you pay for it. Pool stores are in business to sell you mostly unneeded chemicals for your pool, as you are finding out.
    Pool store employee: Sure, We'll test your water for free. We'll give you recommendations on what you need to buy from us to "fix" your pool, using the shotgun approach. Just hand over your wallet and your left arm and leg!
    May 2014
    pa
    5
    Anyhow got the free test while waiting for the kit.
    17,000 gal ag pool sand filter
    TA 140
    ph 7.3
    TH 200
    FC .3
    TC .3
    CA 88
    Pool calculator says to do drain 55% of water and refill. I will start to drain after work today. Anything else I should be aware of. On the print out they say the CA is acceptable. I don't think so. They give their chemical advice that I'm not getting into.
    Oct 2013
    Chapin, SC
    1,141
    That's IF your cya is 100. There's just as likely a chance it's way above that, especially if you're using a pool store test. Even with a good test kit, the test is only accurate to100 or less. If it reads 100, it can be anything above it.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
