Thread: Size of Dipper in Taylor test kit?
    lmnconn's Avatar
    May 2014
    Missouri
    35
    I just received my Taylor test kit and was eager to use it, only to find there is no dipper for the powder used for the chlorine testing. Does anyone know the measurement of one scoop?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Size of Dipper in Taylor test kit?
    Seems this happens a lot and people usually wind up finding it somewhere in the kit. If not, use about the same amount as the size of a BB or a touch more. Work it up from there, but only if you really need too.
    Essential Links:
    38,284
    The amount of powder is not critical if you use enough to get a nice pink. You could use a popsicle stick or the clip sticking out of a bic pen cap.
    lmnconn's Avatar
    May 2014
    Missouri
    35
    Thank you. I did end up finding it in the thin slot where the instruction booklet goes. Hopefully this will be the last test kit I buy. (It's the 4th). I have a Lamotte ColorQ and like the idea of this, but seems I can get varied results testing and then immediately re-testing.
    38,284
    Well it will be the last one you buy this year. You will need to buy refills and they reagents do not last forever. Store it in a cool dark place and it will stay good longer.
