Thread: Drain or fill???
    Drain or fill???
    Hello Everyone,
    Just getting the pool ready. This is a pretty simple question (I think). I have an above ground pool with about 6-8 inches of murky water. I am not sure what approach to take in order to clean it. Should I work to clean the water that is in there and then fill it? Of course it cant be filtered since it is so low so I am only chlorinating it and using a small hose vacuum. Or should I fill it to the fill line and then slam it? I ask this question because I can drain it a bit more but it wont drain completely because the ground is very level.
    16x48 inch Intex pool,6000 gallons, 1000gph pump, TF-100test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Drain or fill???
    With that little water, I would get rid of it and refill fresh.
    Essential Links:
    Ok, I'll try that. Thanks
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Can you throw a pump in there to drain the last of the water? Then you'll have a nice fresh refill....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
