Results 1 to 7 of 7
Thread: Maintaining FC on High Swim Days
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    FC 3.6
    CYA 40
    TA 80
    PH 7.4-7.6
    Finally getting the hang of this.
    I read that if you know you're going to have a heavy swim day/pool party you should raise up your FC ahead of time in preparation for this. Is there a recommended chart of how much I should raise the FC to? Does it matter if it's 5 people or 15? Thanks for the recommendation!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Re: Maintaining FC on High Swim Days
    For 5 people, I wouldn't worry about it. But for 10+ people you want to raise the FC level up to the very high end of the normal range, and for 30+ people raise to just below shock level. The numbers are approximate, the exact number isn't critical. For numbers of people in-between those two, you can pick FC levels in-between the suggestions.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Well, Jason beat me to posting as I was typing, but I think we are essentially saying the same thing...
    At a CYA level of 40 ppm, your target FC level is 5 ppm. I would hold it there if you're looking at a bather load of 5 or so. If you will have 10-15 bathers, then I would raise it up to between 6-7 ppm just prior to your pool party. After the party, I would retest FC and make sure that it is at least at your target level of 5 ppm. Remember, some of the FC loss will be due to sunlight and not just the increased bather load. If you had 10+ bathers and wanted to hold FC at 6-7 ppm overnight for a little extra insurance, there's no harm in doing so. Remember to give your filter some extra run time after the party as the water may be a little more hazy than normal due to oils, tanning lotions, etc.
    Mar 2007
    San Rafael, CA USA
    12,082
    Every person-hour in your 16,000 gallon pool would need around 0.066 ppm FC so 10 people in the pool for an hour would only be a chlorine demand of around 0.7 ppm. Of course, if the people urinate, that's a whole other matter.
    Casey's Avatar
    SW PA
    10,438
    Someone ALWAYS wee wees in the pool.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I have a posted rule that asks for the "P" to stay out of our ool.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Casey View Post
    Count on it, someone will. I will be dosing for compensation...trust me.
    Essential Links:
